Results 1 to 11 of 11
Thread: sticky second gear
08-07-2006, 10:23 AM #1
sticky second gear
sometimes like 6 out of 10 when i have the car at wot it will stay in second and bounce off of the rev limitor for a while then shifts
i checked the fluid and it did seem dark and had a slight burnt smell to it
when cruisin the car shifts fine and never slips, and never did , the car has 111,000 miles and bought it with 99,000.
do you think i can save my tranny by flushing it and installin a shift kit,
08-07-2006, 10:42 AM #2Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Sounds like it is starting to go out.
Were you driving in D or OD?Black 1999 Blown Convertible A4
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
08-07-2006, 10:44 AM #3
08-07-2006, 10:45 AM #4Blown, Stroked, & Sprayed
- Aug 1999
- No Where
I notice on my old stock A4. Driving in D would let the engine rev a bit higher. See if it happens in OD.
08-07-2006, 10:48 AM #5
08-07-2006, 10:49 AM #6Blown, Stroked, & Sprayed
- Aug 1999
- No Where
But if the fluid is dark and smells burnt. You should probably not get on it too much. You may just kill your tranny alot sooner.
08-13-2006, 03:22 PM #7
Service and flush transmission , while you in there use a torx bit to turn the screw in end of pcs (preasure control solinoid 1/4 turn clock wise ,it in center back or the solinoid its the large one ,the solinoid i mean ,
hope this helps for a while but sounds like you will need a transmission very soon
performabuilt
09-01-2006, 11:52 AM #8
how do you drain the torque converter?
09-05-2006, 09:34 PM #9
Well if you have a flush done this would accomplish changing the fluild in the converter but personally I would just do the fluid and filter change and the solinoid mod I mentioned and also look at whats in the pan,
performabuilt
09-06-2006, 02:21 PM #10
Mine does that. Whether spraying or not. I have had two transmissions in it and did it both times until I had it tuned and then it only did it like 3 out of 10 times. It still did it though. I have heard that you actually "starve" the transmission when launching hard and it "hangs" in a gear. But I have no evidence to prove that. Just what I had heard at the local shop on day.
09-08-2006, 05:52 AM #11
Just a note there is a situation in which even though the 3-4 clutch pack is fine and the ecm is comanding the 3-4 shift it may not occur , This can happen particularly when the line preasure has bn raise significantly either mechanically or through programing , You can get a situtation called solinoid flooding , What happens is both solinoids are comanded of during third which means they are venting , However when the line preasue is very high you can get a a situation in which there is so much fluild coming into the solinoid that it cant vent fast enough , This keeps the valve stroked and there by prevents the 2-3 shift until you let of the throttle lowering the preasure ,
For those of you with a tuner try lowering (I know this goes against the grain)Line preasure at full throttle and see what effect this has , If it improves it or fixes it , You might consider getting some new solinoids from a company called fitzall they are a general replacement solinoid but have a larger vent ,
Just a possibility
PerformaBuilt
2002 Camaro ss a4 Help! redlines a gear then changes a gear from a roll please read!
By hmorris7000 in forum Camaro / SSReplies: 24Last Post: 06-05-2007, 03:01 PM -
By hmorris7000 in forum General HelpReplies: 9Last Post: 06-01-2007, 05:18 PM
