Results 1 to 16 of 16
Thread: thud shifting from 1st to second
08-04-2006, 05:50 PM #1Senior Member
- Sep 2005
- rochester,ny
pewter- 2001 z28 lingenfelter 383
my car often makes a loud THUD when shifting hard near red line from 1st to second..i have an aftermarket aluminum driveshaft lingenfelter installed. What do u think this thud could be? and how come my tires arnt breaking loose instead.....somtimes both happens.....thud and they break loose.and somtimees they just break loose.....but MOST of the time it makes that thud ..its a god awful sound...other than that everything seems perfect with the car/tranny ..any suggestions???
08-04-2006, 06:16 PM #2Senior Member
- Sep 2005
- rochester,ny
forgot to mention...prolly important to know car isnt running drag rads ....mich pilot sports with about half tred life left.....they grip well but THEY should be giving in second not somthing else
08-04-2006, 06:17 PM #3Senior Member
- Sep 2005
- rochester,ny
m6 car as well....lol im good at lacking info..and the clutch holds VERY well....spec 3 barely broken in
08-04-2006, 07:04 PM #4
check you trans and torque arm mount.
08-04-2006, 07:58 PM #5Senior Member
- Sep 2005
- rochester,ny
hum..still new to this stuff...any explaination on where i can find the tranny mount and tourqe arm would help tons n tons..i certianly have an idea but ill take all the advise i can get..lol.....suspension is stock btw in reguards to the tq arm ..thank you
08-04-2006, 08:00 PM #6
at the back of the transmission
08-04-2006, 09:01 PM #7Senior Member
- Sep 2005
- rochester,ny
ty for the pic..ill check it out tomorrow....am i looking for it to be loose? broken? looks pretty simple
08-05-2006, 09:53 PM #8
Good pic...I believe my torque arm bushing/mount is falling apart, last time I was under there the rubber part was all split apart pretty bad.
Wheres a good place to get a replacement torque arm mount??
08-06-2006, 07:46 AM #9
energy suspension make a poly version for stock arms. other than that, back to the dealer for a stock replacement. the two halves are riveted on to the brackets. so, you may have to buy the whole assembly from the dealer.
08-07-2006, 01:37 PM #10Senior Member
- Sep 2005
- rochester,ny
ok went to new era performace today..great guys over there...they took a look and the tranny mount was fine and i had a bmr tq arm put in..after doing both the thud is still present...they think it could be the spec clutch as theve seen them do this before where they grab then skip and it makes a thud....have u guys heard of this out of spec? it was made in 01 spec 2 or 3 maybe? dunno what to do....if i spend the money on a new clutch and the prb is still there im gonna be pissed...as mine feels fine otherwise..whats everyone think?? thanks
08-08-2006, 11:20 PM #11Member
- Nov 2005
- allenhurst GA
onyx black- 1999 formula firebird
never heard that bout a clutch before.. i have had a spec 1 and now a spec 2 with their billet steel flywheel...and i dont have a thud..only time i did i had ripped my polyeurethane bushings for the torque arm and the tranny mount both..
08-11-2006, 01:25 PM #12Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
sounds like it could be the slave cylinder
08-11-2006, 01:27 PM #13Senior Member
- Sep 2005
- rochester,ny
really? how could the master slave cylinder cause this prb? and its a 2001 so it already has the updated master slave???? would def be a cheaper fix if that IS the prob...my clutch pedal rides very high as well..feels ok though..thanks for the replies..keepem coming .i want to get this fixed but i dont wanna spend thousands trying diff things to make it happen
08-11-2006, 01:34 PM #14Senior Member
- Aug 2003
- Honolulu HI
reason i say that is because when mine was thudding going in and out of first, it was because of my slave cylinder. yes your master is updated, but that doesnt mean it cant and wont fail. New Era is just right there like you said. I got my ram adjustable master cylinder from Mike. It was a simple install..well to me it was.
08-11-2006, 02:05 PM #15Senior Member
- Sep 2005
- rochester,ny
what do u think of your ram?and which one did u get? total cost? thats what mike suggested to me..im at about 450 flywhl horse now and only plan on adding headers in the future to top it out around 480 so i dont need anything to rediculous....i like a near stock feel with lots of grip.
08-11-2006, 02:34 PM #16Senior Member
- Aug 2003
- Honolulu HI
my setup is as follows:
ram billet flywheel
ram powergrip HD
new slave
Its a great setup, but stiff. I dont mind it though. this is my second ram. I replaced the first because i blew the slave and knew before it went out it had to have been giving uneven pressure causing uneven wear on the clutch.
Help with Thud Sound
By 99WS6MAN in forum General HelpReplies: 7Last Post: 10-27-2010, 06:42 PM -
Thud Thud Thud Thud/ Where is this noise?
By Hi-Po in forum General HelpReplies: 27Last Post: 04-29-2009, 03:54 AM -
Rearend clunk/thud...
By CamaroFan71 in forum General HelpReplies: 4Last Post: 02-04-2009, 07:32 PM -
Thud/knock/bump
By UKXK189 in forum General HelpReplies: 4Last Post: 07-18-2007, 10:39 PM -
thud noise when shifting.
By johneboy71 in forum DrivetrainReplies: 8Last Post: 08-20-2006, 04:48 PM
