    Member 99WS6MAN's Avatar
    TX
    99 Pontiac WS.6 Trans Am
    Question Help with Thud Sound
    Just yesterday I noticed a loud thud when I go over bumps from my rear end ... I did some searching and found that it may be my bushings but is there any way that I can be for sure of this? I'm a novice when it comes to repair on the Bird but I'd like to try it out any way ... it sounds like its coming from the driver side rear and sound like I'm bottoming out and is LOUD
    Thanks in advance
    99 WS6 Trans AM
    Hurst Shifter
    Aftermarket Throttle Body
    KN Air Filter
    Strut Tower Brace
    Z06 Rims
    Jul 2010
    Navy Blue
    1999 Camaro Z28
    Sounds like bushings... how many miles are on the car?
    Take a look at the suspension system. You'll see the bushings in there (black rubber mounts at connection points.) See if they are cracked.
    TX
    112,000 and counting ... how hard is it to change those out? The sound is really loud at times and it sounds like I'm messing something up
    Jul 2010
    Navy Blue
    1999 Camaro Z28
    What are your plans on the car? If it's a DD and/or you plan on keeping it for a long time AND keeping stock suspension, you can get complete rebuild kits and it's not all that hard. Doesn't all have to be done it one rip. Do one side, then the other, starting where you hear the noise. 100k miles is time to start inspecting bushings.
    If you plan on moding the suspension, no reason to rebuild bushings that you are about to remove. Look for what's worn out the most (I've seen entire bushings disintegrated on cars,) and think about replacing that first.
    Member bberretta's Avatar
    Aug 2009
    Memphis, TN
    Bright Red
    2000 TA Firehawk 0041/742
    Do you feel it in the trans? Could also be the TA mount. Start with the TA mount and the control arms. Also check out the shocks- how bad are they? If one shock is bad enough then it will easily slam up into the bumpstop which may have long since deteriorated.
    2000 Pontiac Firehawk #0041 of 742
    Orlando, FL
    Mean Black
    i will check the shocks and springs. My shocks and springs were bad and it was hitting the bump stop. I had to replace the shocks, spprings and bump stops.
    also check your torque arm... i split my stocker in half and had a nice thud going over bumps... check the area where it bolts in to the rear...
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Keep us posted OP.
  1. Thud Thud Thud Thud/ Where is this noise?
    By Hi-Po in forum General Help
    Last Post: 04-29-2009, 02:54 AM
  2. Rearend clunk/thud...
    By CamaroFan71 in forum General Help
    Last Post: 02-04-2009, 06:32 PM
  3. Thud/knock/bump
    By UKXK189 in forum General Help
    Last Post: 07-18-2007, 09:39 PM
  4. thud noise when shifting.
    By johneboy71 in forum Drivetrain
    Last Post: 08-20-2006, 03:48 PM
  5. thud shifting from 1st to second
    By tonyjnjz in forum Drivetrain
    Last Post: 08-11-2006, 01:34 PM
