07-22-2006, 05:59 PM #1
- Texas
Pewter- 2000 Z28
Need some help after Intake/Cam install
I have 2 connections I can't figure where they go. There is a wire/sensor plug located on the drivers side, by the #7 fuel injector plug that I can't figure out where it goes. Also, I installed the new Professional Products intake and on the front of it, on the passengers side, need where the throttle body is bolted, is a outlet that I can't figure out where it is suppose to attach.
Any help would be greatly appreciated. The car will start and run, but when you give it more than slight throttle, it bogs down and doesn't want to speed up.
07-22-2006, 06:09 PM #2
- Wahiawa hi.
black- 2000 Camaro SS
post up a pic of the wires, its hard to tell from the discription, but with a pic id be able to tell you quick
07-22-2006, 06:54 PM #3
- Texas
Pewter- 2000 Z28
Here you go the first one I had plugged as I think it went to the AIR system, which I removed.
The second image, I had the red plug and white plug attached to the connectors next to them.
The third image is of the connector I can't figure out.
07-23-2006, 02:55 AM #4
- Wahiawa hi.
the second pic looks like you had the plugs in the right place.. remember, all of your connectors will only connect in one place..
the third pic, not sure, but make sure you have these two connectors hooked up, kinda looks like the oil pressure sending unit connector, but not 100%
07-23-2006, 06:46 PM #5
- Texas
Pewter- 2000 Z28
I found the tubing for the PCV that runs from the Intake to both valve covers, so that mistery is solved, now I just need to find out where the connector in the 3rd picture goes. I guess I will have to tear the intake off and see if I can find it that way. It still runs with a hesitation, kind of like it has a vacuum leak.
Thanks for all your help.
Question: F.A.S.T Intake Install
By Dr.Crash in forum External EngineReplies: 17Last Post: 02-05-2009, 03:28 PM -
Intake install
By Wheeler99WS6 in forum External EngineReplies: 0Last Post: 04-09-2007, 04:38 PM -
what to a intake install
By momsls1 in forum External EngineReplies: 4Last Post: 09-20-2006, 11:46 PM -
ls1 intake install
By wayfastws6 in forum External EngineReplies: 1Last Post: 04-16-2006, 10:51 AM -
ls6 intake ? INSTALL KIT
By skar in forum General HelpReplies: 3Last Post: 02-27-2006, 02:37 AM
