Results 1 to 18 of 18
    TJEA Retirement Home Dr.Crash's Avatar
    Feb 2006
    U. S And A Greatest country in all of world
    Stock
    2002 Camaro
    F.A.S.T Intake Install
    *Intake w/Gaskets
    *TB w/Gasket
    Is there anything else that i need to do this install. Anything i should know before i get into it? thanks
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Hmmmm.. you will need different valley cover bolts. Silicon the MAP sensor in or make a raised washer to hold the sensor in. The FAST does NOT have a "clip" to hold the sensor in place. Really just relies on it staying seated. I reused my intake gaskets. Worked fine.
    Be careful taking your LS1/:S6 intake out... Dont screw your oil pressure sensor up...
    Make some small tube for the 4-5 bolts on the back of the intake when you install the FAST. They need to be held up. You will never get the bolts in if you do not have them installed an inch or so into the intake before sliding it under the firewall. I personally just wrapped a piece of masking tape around the bolts after I had them in the intake holes. There are many was to hold the bolts up, it will have to be done though.
    Take your time.
    Dont drop anything into your head. I did.... I dropped a washer onto the top of the intake valve. I happened to check before installing and by the grace of the LS1 god... found the washer sitting on top of my valve. I almost killed it! Dont do like I did. Take your time.
    Feb 2006
    Stock
    2002 Camaro
    where do i get the valley cover bolts? which ones?
    Florida
    1999 TA WS.6
    Quote Originally Posted by Dr.Crash View Post
    FAST sells them, I bought them off them. But then they decided to never ship them to me. Good times.
    They dont cost nothing, just call FAST and ask them for the valley cover bolts for your FAST to sit right.
    Also, many.many parts stores will have them. They(FAST) will give you the bolt dimensions. I got them. I think they will give you a allan head bolt, I work for Caterpillar... so I bouth some from them, seeing how they have abouta a million bolts in stock.
    Well, Caterpillar bolts, to FAST dimension were even higher. I ended up just grinding down my bolt heads to make it sit right. It worked, not the prettiest. But I had to have my TA back on the road.
    Senior Member rajiv1998's Avatar
    New Jersey
    1998 Pontiac Trans Am
    Take ur time, and do not i repeat DO NOT break your oil sending unit. Actually its not a big deal if u do. Most of the people who swap intakes break it their first time around.
    FAST (comp cams) will send out new valley cover bolts with a new intake.
    Lowered, HID's, tinted.
    Florida
    1999 TA WS.6
    Quote Originally Posted by rajiv1998 View Post
    Damn, yea.. its the sending uit... My bad. Its easy to break if your not really careful.
    Florida
    1999 TA WS.6
    Sometimes! They never sent me mine. Sonsofbitch's.
    It all worked out in the end.
    Feb 2006
    Stock
    2002 Camaro
    Well I am going to buy one thru KYspeed. do they send them as well?
    Orlando FL
    Red+White Top and Stripes
    2000TransAmConvertible A4
    Haha, I was 17 when I did it, the FAST was one of my first mods I had next to no experience and I didn't snap the sender.
    Oh, and when you put in the bolts use tape to hold them in when you place the manifold over the motor. The bolts won't clear the cowl, you actually have to put the bolts into the intake before putting the intake into position, but hold the bolts high enough that they clear the motor on the bottom. Pain in the ass right? You're going to hate the cowl by the time your done.
    That's cute
    If it is new....they had better.
    FAST packs them in with the intake.
    If they aren't there....call COMP.
    Feb 2006
    Stock
    2002 Camaro
    Thanks. so all i need to do now is decide what kind of beer to drink while i am installing!
    Member marksls1ta's Avatar
    pikeville, kentucky
    1998 trans am
    the bolts are included with the intake as it is a new in box one.
    thanks, Mark @ kyspeed
    www.kyspeed.com
    pikeville, kentucky
    1998 trans am
    thanks for the order PM sent
    www.kyspeed.com
    Feb 2006
    Stock
    2002 Camaro
    PM replied. Thanks again
    Feb 2006
    Stock
    2002 Camaro
    Hey is there not a hole on the blade of the 92MM fast TB? i didnt see one in the pic online. Thanks
    Orlando FL
    My 90 doesn't, I don't know about the 92. Really the TB is so big it shouldn't really need a hole since there will be so much air flowing in from around the edges.
    Florida
    1999 TA WS.6
    My PTM 92mm has a small hole.
  1. Intake install
    By Wheeler99WS6 in forum External Engine
    Last Post: 04-09-2007, 04:38 PM
  2. what to a intake install
    By momsls1 in forum External Engine
    Last Post: 09-20-2006, 11:46 PM
  3. Need some help after Intake/Cam install
    By Barry00Z in forum External Engine
    Last Post: 07-23-2006, 06:46 PM
  4. ls1 intake install
    By wayfastws6 in forum External Engine
    Last Post: 04-16-2006, 10:51 AM
  5. ls6 intake ? INSTALL KIT
    By skar in forum General Help
    Last Post: 02-27-2006, 02:37 AM
