Thread: Piston to Valve Clearance
07-18-2006, 08:08 AM #1Junior Member
- Jun 2006
- Augusta GA
grey- 02 GMC Sierra
Hey I was wondering if anyone knew how much lift you can get away with on the 5.3 truck motor with stock ratio rockers? I'm planning on using the Dart heads and comp springs good to .600 lift, but for the time being I'm going to use the stock heads with the comp springs. Any help would be great
07-19-2006, 05:53 PM #2Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
PtoV isnt measured by the lift of a cam, but rather the duration and lsa. You need to also have the gasket thickness and milling of the heads taken into consideration too.
08-04-2006, 06:45 PM #3
lift has a factor in it, but your more in harms way with the duration and lsa for sure. the only real way to know is to clay that engine and check.
08-04-2006, 09:41 PM #4
What would be too much Duration, LSA, and Lift to run with stock heads and rockers?
quench and piston to valve clearance
By blackula 99 in forum Internal EngineReplies: 6Last Post: 08-26-2009, 07:54 PM -
piston to valve clearence with crane cams quick lift rocker arms?
By Rob00Taws6 in forum External EngineReplies: 3Last Post: 06-22-2007, 02:19 PM -
piston ring side clearance
By white99SS in forum Internal EngineReplies: 4Last Post: 05-07-2007, 12:43 PM -
piston to valve clearance?
By oneBADDz in forum Internal EngineReplies: 10Last Post: 06-23-2006, 08:02 PM -
HELP...valve/piston clearance problem!!!
By kevinpickering in forum Internal EngineReplies: 5Last Post: 02-07-2006, 11:41 AM
