08-17-2009, 03:30 AM #1
quench and piston to valve clearance
Have a ls1 block with ls6 cnced heads milled to 59cc.I am going to run the comp cams 224/230/581/588 cam {273xer} on a 114lsa. Was going to run a 051 head gasket[mls] Is there a fear of piston to valve clearance with this combination and , quench...is this far from optimum? maybe a .040? Can I even run this thinner gasket with this combination? Thanx in advance
08-17-2009, 03:32 AM #2
i don't forsee any issues. i've read where people have used thinner head gaskets with no issues.
08-20-2009, 05:13 PM #3
Quench distance is also affected by how far the pistons are in the hole. Always check piston the valve clearance when changing components. It doesn't take long, is not hard, and is much better than finding out after the engine is running that you have a collision.
08-21-2009, 03:42 PM #4
As far as your quench goes, On my build, the pistons came out of the block .010" and I used the .051 gasket for a .041" quench. So that's great. That cam should fit with no problems. It is easy to check the valve to piston clearance. Put two light springs on your # 1 valves, so you can push them open with your fingers as you turn over the motor. Read this link on degreeing a cam !!!
http://69.20.53.62/pdf/803.pdf
08-26-2009, 10:14 AM #5Member
- Feb 2006
- MD
Is anybody actually reading what has been posted!?
Heads milled .030". Larger valves than stock. That cam MAY clear with the .051" gasket. No way will it clear with the .040"
08-26-2009, 02:04 PM #6
You choose the gasket according to the piston highth, and your shooting for .035" - .045" quench... Then, you want to degree the cam to make sure it fits. If not, the pistons will need fly cut.
Just from experience, I'm saying his combo will not have any clearence issues. You don't want to use the gasket thickness to give more room for the valve to piston clearence.
08-26-2009, 07:54 PM #7
That cam will clear on heads cut .030, but I would run a stock GM MLS gasket.
piston to valve clearence with crane cams quick lift rocker arms?
By Rob00Taws6 in forum External EngineReplies: 3Last Post: 06-22-2007, 02:19 PM -
piston ring side clearance
By white99SS in forum Internal EngineReplies: 4Last Post: 05-07-2007, 12:43 PM -
Piston to Valve Clearance
By SFR292 in forum Internal EngineReplies: 3Last Post: 08-04-2006, 09:41 PM -
piston to valve clearance?
By oneBADDz in forum Internal EngineReplies: 10Last Post: 06-23-2006, 08:02 PM -
HELP...valve/piston clearance problem!!!
By kevinpickering in forum Internal EngineReplies: 5Last Post: 02-07-2006, 11:41 AM
