    New Jersey
    1995 LT1
    What Fuel System????
    Whats the best Fuel Set up I can get without going with a Fuel Cell. I was going to go with the Aeromotive Eliminator EFI system, but I would need a Fuel cell and I dont want to go that way. Are any of you running a intank set up, so that you don't need a Fuel Cell/Sump pump, and does it still give you the Volume you need..... My car is ready to go I just need a Fuel System
    383 Forged
    D1SC 14psi FMIC
    75lb injectors
    Thanks
    John
    Member cailey37's Avatar
    Mississippi
    1998 Pontiac Trans Am
    Quote Originally Posted by jmangler View Post
    383 Forged
    D1SC 14psi FMIC
    75lb injectors
    Thanks
    John
    Why would you need a fuel cell??? Just have some AN fittings welded on your tank and run the lines.....boom...you're in business...
    New Jersey
    1995 LT1
    I will have to look into that! Thanks for your help! Just have to find someone who can get it done for me!
    Mississippi
    If you can find someone that can TIG weld good then you're in business.....the rest is running fuel lines.....not sure what car you're putting it on and if you want a return line......but if you have a returnless system then I'd think about getting a line run back into the tank......it may sound complex but it's really easy.......and in the end well worth it....also, if you're planning on running that a lot on the street go ahead and get a Fuel pump controller now...it will save the pump!!
    New Jersey
    1995 LT1
    Its going in the LT1 Camaro. May sound stupid but, What do you mean Fuel pump controller....
    Mississippi
    It's a Fuel pump controller that you can put on your car to actually slow down the fuel pump so it doesn't heat up....like when you're ideling or driving around town.......go to this link:
    http://www.jegs.com/webapp/wcs/store...tegoryId=10767
    It just basically steps the voltage down to the unit based on your RPM.....and gives you 100 percent when you need it.....
    If you plan on driving the car around town you'll want to invest in one of these.......you can also go on Froogle and type in Aeromotive Billet Fuel Pump Controller. I found one on there cheaper than other places.......
    New Jersey
    1995 LT1
    Thats a great idea!
    Thanks
  1. Ls1 fuel system
    By Kyle77 in forum General Help
    Last Post: 03-03-2012, 07:43 AM
  2. Help: Fuel System for STS
    By 1slowbusa in forum Forced Induction
    Last Post: 03-13-2011, 10:02 AM
  3. fuel system
    By tk66k in forum Nitrous
    Last Post: 06-11-2008, 11:01 AM
  4. Fuel system
    By Footloose in forum External Engine
    Last Post: 08-31-2007, 01:29 PM
  5. Fuel System....
    By jmangler in forum LT1
    Last Post: 08-22-2006, 02:15 PM
