Results 1 to 3 of 3
Thread: 3 ses codes no mil light
07-10-2006, 01:58 PM #1
rented a code scanner from autozaone and picked up 3 Codes P0103(maf circuit high input)....p0113(Iat sensor 1 circuit high input)......and p0122(tps/pedal positioning sensor a circuit low input).............SO i decided that the tps was the culprit and when i pulled the sensor connector it was covered in oil!!!and i unscrewed the unit cleaned it out and shes runnin ok for now but....can You guys give me any input on this and what should i do??
07-10-2006, 02:07 PM #2
So there was oil in the connection? Between the harness and tps?
07-10-2006, 02:15 PM #3
yea when i pulled the plug to the tps sensor it was coated in oil...and then i pulled of the sensor and it had oil in it also which i sprayed out with cleaner...is this a common problem?and did it cause the other to codes to go off? the guy at autozone was telling me to buy a new maf???..but i refused
Engine light codes?
By smokinsam in forum General HelpReplies: 10Last Post: 04-24-2015, 10:31 PM -
SES light .... but no codes??!
By speedyWS6 in forum Firebird / WS6Replies: 22Last Post: 10-29-2010, 10:00 AM -
flashing ses light but no codes??
By VENOMOUS in forum Computer & TuningReplies: 13Last Post: 12-16-2008, 01:14 PM -
Help: SeS light and Codes
By Justin93 in forum General HelpReplies: 2Last Post: 10-02-2008, 11:11 AM -
Help Ses Light Rich Codes
By GNICTRY in forum Firebird / WS6Replies: 8Last Post: 02-13-2008, 06:24 AM
