07-10-2006, 08:15 AM #1The Mudkat
- Jun 2006
- "The good Lord sez he can get me outta this, but he sez he's pretty sure you're *****d!"
white- 2000 SS Convertible
Alignment Specs Needed for this setup!
35mm sway, Koni S/A's lowered 3/4 in front and heater hose mod in back. Stock SS springs on the koni's. It's not a drag car...daily driver and sometimes autoX car. 275/40's all the way around. I just put the Koni's in at full soft in rear (due to PHB and LCA's being on the car) and 3 window turns from full soft in front. Thanks!
Mudkat
07-10-2006, 01:34 PM #2
camber -0.50* l and r
caster 4.50* l and 5.00* r
toe 0.03* totalCold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
07-10-2006, 06:26 PM #3Crazy Canuck !
- Jun 2002
- Montreal, CANADA
agree with the above statement.
Note that the difference in toe from left to right is to compensate for your weight when you are in teh vehicle.
I do my alignments inside the car, so the weight is with me in it, and make it equal on both sides then... just ask your alignment person.
For starters:
camber: -0.5'
castor: +4.5' on both sides (with you in it)
toe: start with 0" or a bit of toe-out
note that toe-out is great for steering response and auto-x, but affects tire-wear and high speed stability... toe-in will give a bit of high speed stability and less of a highly responsive steering... hence the reason for starting @ 0 toe and go from there.
Also, if by any chance, you can't get these #s, try going to +4.5 castor and as much negative camber as you can... but you should be able to with the Koni SA, if you used the lower perch location.Eugenio_SS
07-10-2006, 06:29 PM #4
07-15-2006, 11:26 AM #5
alignment specs?
By 0verkill in forum Suspension and HandlingReplies: 2Last Post: 05-24-2010, 09:38 PM -
Question: Alignment specs
By 99yellowz28 in forum Suspension and HandlingReplies: 3Last Post: 09-26-2009, 06:39 AM -
Question: Alignment Specs
By markw in forum Suspension and HandlingReplies: 1Last Post: 04-02-2009, 07:43 PM -
road race alignment specs
By cm2papa in forum Road Racing / AutoXReplies: 20Last Post: 02-19-2009, 12:29 PM -
C6 'vette alignment specs
By b1dude in forum Wheels and TiresReplies: 3Last Post: 07-08-2008, 05:29 AM
