Thread: Alignment specs
09-19-2009, 08:17 AM #1
Alignment specs
I got UMI Adj panhard bar,Adj lca's,lca relocation brackets,Adj tunnel mount torque arm and eibach proline springs. Should my car be aligned to factory specs and how should the torque arm be adjusted.Also dose model #[2202] adj torque arm work with stock maniolds and y-pipe, plan on getting hookers later
http://kentucky-speed.com/umi-perfor...fba6ee7c229acbLast edited by 99yellowz28; 09-19-2009 at 08:20 AM.
09-19-2009, 05:46 PM #2Junior Member
- Oct 2008
- Cary, NC
Pewter- 2000 Pontiac Trans am M6
theres a youtube video on how to adjust a torque arm
09-19-2009, 07:49 PM #3
09-26-2009, 06:39 AM #4
to factory specs is up to you. with the adjustable trailing arms, they can now set thrust angle to 0.00*. make sure you tell them you have that adjustability because normally these cars don't.
alignment specs?
By 0verkill in forum Suspension and HandlingReplies: 2Last Post: 05-24-2010, 09:38 PM -
Question: Alignment Specs
By markw in forum Suspension and HandlingReplies: 1Last Post: 04-02-2009, 07:43 PM -
road race alignment specs
By cm2papa in forum Road Racing / AutoXReplies: 20Last Post: 02-19-2009, 12:29 PM -
C6 'vette alignment specs
By b1dude in forum Wheels and TiresReplies: 3Last Post: 07-08-2008, 05:29 AM -
Alignment Specs Needed for this setup!
By heliskiier in forum Suspension and HandlingReplies: 4Last Post: 07-15-2006, 11:26 AM
