Thread: Idle Problem. + others.
07-07-2006, 12:35 PM #1Junior Member
- Jul 2006
- Indianapolis
Dark Green- 1991 Firebird
1991 Firebird V8,
Ok here goes what its doing,
In the Morning it Idles way past 1000 rpms, then after about 5 to 10 mins, it goes into normal idle, also sounds like a miss or idles funny all day sometimes.
Tranny also jerks into gear when in reverse or overdrive.
Anyideas what to look for?
07-07-2006, 04:15 PM #2Junior Member
- Jul 2006
- Indianapolis
Anyone?
07-07-2006, 07:15 PM #3
I dont think that is a biggie. My ws6 idles about 1200 rpms upon starting and if u let it set for like 10 seconds it will drop to 800
07-08-2006, 12:39 AM #4Junior Member
- Jul 2006
- Canada
Black- 1987 Firebird
For you idling problems... I can't really suggest anything other than getting a qualified mechanic to look at it, they should be able to fix whatever the problem is relatively cheap... so find a mechanic you trust/like... that's what I did anyways =P
As for you tranny, I was also having the same difficulties.... check out your tranny mount... esy enough to spot... mine looked like it had exploded =[ Costs of replacing it are really cheap as well... I think I paid $15 for a new mount and I already had a jack =P Bit of a pain in the ass to do yourself but it saves about $200 (quote)
Hope some of that jargon helps
07-08-2006, 07:03 AM #5Junior Member
- Jul 2006
- Indianapolis
thanks, it does help.
07-18-2006, 03:59 AM #6
there was a thread on here that explained how to fix electric windows. well, mine quit working and now i can't find it. could use some help here. thanks
Help: Idle Problem!!!
By 00hawk109 in forum General HelpReplies: 7Last Post: 10-11-2011, 01:38 PM -
01 S-10 4.3l idle problem
By TwinTA in forum GM TrucksReplies: 5Last Post: 03-28-2009, 02:17 PM -
Question: different idle problem
By Brad(WS/Z0.6) in forum General HelpReplies: 16Last Post: 01-31-2009, 07:19 AM -
Idle Problem please help
By christrusler in forum General HelpReplies: 18Last Post: 01-25-2009, 07:16 AM -
idle problem
By occamaroz in forum General HelpReplies: 4Last Post: 06-17-2006, 09:00 AM
