    Junior Member TwinTA's Avatar
    Jan 2008
    Connecticut/Hawaii
    95 TA & 99 TA - Sold 99
    01 S-10 4.3l idle problem
    I have my truck in storage right now, im in the process of selling it. I had a friend go and start it up, he said there was not problem, battery was good, but as soon as he dropped it into gear it wouldnt idle. What could this be? Before i stored it i added fuel stabilizer. Could it be the Torque converter? a sensor? or EGR valve? I had someone one another web site say it could need plugs, wires , and tune-up, but i doubt it, if it was that it would run like crap as soon as you start it.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by TwinTA View Post
    Could be almost anything. Is the check engine light on?? If so, pull the codes and diagnose from there.
    If not, knowing that the 4.3's often have trouble with leaking fuel injector (spider) assemblies, that is a definite possibility. What happends is the fuel injection system, which is located in the lower half of the intake, begins to leak. So you get raw, un-atomized fuel dumping into the intake ports. This results in rough idle, stalling, poor driveability, and usually black smoke out the exhaust.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Quote Originally Posted by Wesman View Post
    Hit that right on the dam head
    Member Goldcuffs's Avatar
    Aug 2008
    Florida
    2000 Trans Am
    IAC, idle air control valve. You can find it right on the side of the T/B.
    Jan 2008
    Connecticut/Hawaii
    thanks for the info, ill test it out as soon as i arrive in the states Thanks again!!
    Import Killer SLP00blueSS's Avatar
    MIchigan
    also 4.3 are known for bad intake gaskets, i had the same problem on my 98 intake gaskets went. had them changed and all good
  1. Help: Idle Problem!!!
    By 00hawk109 in forum General Help
    Last Post: 10-11-2011, 01:38 PM
  2. Question: different idle problem
    By Brad(WS/Z0.6) in forum General Help
    Last Post: 01-31-2009, 07:19 AM
  3. Idle Problem please help
    By christrusler in forum General Help
    Last Post: 01-25-2009, 07:16 AM
  4. Idle Problem
    By larryndog in forum V6
    Last Post: 08-13-2006, 04:55 PM
  5. idle problem
    By occamaroz in forum General Help
    Last Post: 06-17-2006, 09:00 AM
