06-30-2006, 08:38 PM #1Junior Member
- Nov 2005
- pa
black- 1999 camaro
1st Time running at the track... could of been better
Well I went to the track this Friday and didnt do as good as i would of liked to. I have a 99 m6 z28 with about 350 hp. I would of done pretty good but my launch's killed me. I was trying to baby the clutch out instead of dumping it n i think it was hurting me. i had two 2.3 and two 2.2 60' times. i missed 4th my first time n ended up runing a 14.0 then i did ok the next run and got a 13.9 @ 104. The next run i went against a 06 GT( I really wanted to take him) so i eneded up dumpping the clutch a little more then i would of liked to but i took off out of the hole and had him by a car but some how i missed second. I got it back in n started to run him down but it was too late, he ended up with a 13.6, i should of had a 13.5 or better if i didnt miss that dam shift. And i really need to get some new tires, these 245's spin like crazy. Hope to do alot better next time, i think im starting to get the hang of it.
07-02-2006, 10:05 AM #2Junior Member
- Nov 2005
- pa
black- 1999 camaro
If anybody has any tips on how they launch there m6 w/ street tires i would like to hear them. i feel like if im not spinning then im bogging out, just cant win with these tires. thanks
07-10-2006, 08:28 AM #3Junior Member
- Nov 2005
- pa
black- 1999 camaro
Well i went back this weekend and did alittle better. I ran a 13.8 then a 13.7 but still spinning ike crazy, really need to get some radials on the car.
07-18-2006, 04:01 PM #4
here's how i've been telling people with manuals how to launch. hold the rpms to about 2200 rpms with the clutch pedal up to the point to just before it engages. when it's time to go, let out the clutch WITHOUT adding gas pedal. if it's hooking, then add as much gas pedal as you can without breaking loose the tires. if tires spin on launch, decrease rpms at launch. if bogs, add more rpms to launch. if you spin, let out and get back in it. the more you spin, the worse the ET. we all know this, we just keep forgetting to let out and get back in.
also, add your times to the ET listing.Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
Running 12.5 at 109mph is my best time EPS 222/226 cam
By Durango in forum Drag RacingReplies: 9Last Post: 11-27-2012, 06:16 AM -
Question: Kicked off the track for running too fast. Need cage.
By matt evans in forum General HelpReplies: 27Last Post: 11-30-2011, 09:12 PM -
MVP Track Time 2010 Track Schedule
By Feffman in forum Road Racing / AutoXReplies: 0Last Post: 12-09-2009, 09:45 AM -
what time should I be running??
By mattycakes98TA in forum Firebird / WS6Replies: 2Last Post: 08-18-2006, 03:05 PM -
First time ever running the 1/4 mile.
By amit in forum Drag RacingReplies: 8Last Post: 06-27-2006, 02:52 PM
