Results 1 to 13 of 13
    Vienna WV
    98 Trans Am
    17s in front 18s rear?
    Any buddy got pics of a T/A with 17s in the front 18's in the rear? What size tires would look good also?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    not a TA, but the wife's formula just got factory C5 silver wheels. 17 x 8.5" and 18 x 9.5" with 255/45-17 and 285/35-18 nitto nt555 tires. had to some minor clearancing so the rear tires didn't rub the inner fenderwell.
    Black Beast 1 badblack transam 01's Avatar
    North Carolina
    2001 Trans Am WS6
    Sweet ride, but imo it would look better with same width tires in the front thats in the back. Does it ride good like that? JW
    orlando, fl
    2014 camaro 2ss/rs
    while i like to have the same tire all the way around, the issue comes when you have two different size and width wheels. remember, the C5 corvettes came this way. the tires on the C5 are 245/45-17 (25.7" tall) and 275/40-18 (26.6" tall) many of your high end import italian/german cars do this as well. it's a balance of oversteer/understeer as a result of tire widths and heights.
    in the case of what i did with the wife's car is both, the 17" and 18" tires, are 26" tall. this keeps the ABS system happy as it's programmed to recognize the front/rear to be turning at the same speeds.
    as far as widths are concerned, i could have put a 275/40-17 tire on the front wheel. but, it would pull the tread area over because the rim is only 8.5" wide. in my many years of tire and wheels selling, i learned that so long as the TREAD width doesn't surpass the rim width, you don't have ride/vibration concerns.
    to answer your question, the car handles very well. i've never had 18" wheels before. the rear was very stiff and secure in the corners. the front was smooth in the turns. ride isn't rough, but you feel the road imperfections more. typical with small sidewall tires.
    i've had 275/40-17 on my black car for a year now. and i've ran on v rated or better for quite a while now. so, i know what to expect out of a tire.
    jhoward7285
    Guest
    I also have the c5 wheels, but I have the Eibach sportline springs. I had to do some coaxing to the inner fenders to get them to not rub while driving and they still rub slightly under hard cornering so here in the future I am going to switch to the pro springs. Here it is;
    You can see more at http://www.cardomain.com/ride/2356658/2 if you want.
    Vienna WV
    98 Trans Am
    thanks guys would a different offset help with the same width wheels?
    jhoward7285
    Guest
    Quote Originally Posted by daveb91 View Post
    Yeah it would bring them out a little bit farther, just dont get the sportline springs then because your tires might actually hit the inside of the fender right above the tire.
    Vienna WV
    98 Trans Am
    I meant move them in so they wont hit the inner fender. Is there enough room away from the suspension to move most 17 and 18 wheels in so they wont hit?
    jhoward7285
    Guest
    If you move them in farther they will rub worse. They do not hit the actuall inner fender, they hit the very back of the wheel well.
    orlando, fl
    2014 camaro 2ss/rs
    you can buy the appropriate offset wheels so they do not hit anywhere. my american racing 17 x 9.5 wheels with 315/35-17 tires never hit anywhere.
    Vienna WV
    98 Trans Am
    Thanks anyway of knowing what offset will fit for a certain size and width of wheel or is this something a good wheel and tire shop should know?
    Junior Member WS.SICK's Avatar
    Pomona California
    2000 WS.6 T/A
    black ta's with black rims are sickness
    Member NHRAMAN's Avatar
    Vancouver,B.C.,Canada.W.Coast
    '99 T/A WS6 M6
    Thumbs up
    Quote Originally Posted by WS.SICK View Post
    Mean Machines ..........
    99 WS6 M6 NBM !Cags,!Cats,Vinci/Crane,Hurst,Detroit TruTrac,3:73,31 Splne,Edel.Race LT's,ORY,QTEC,Flow,ARP,Percy,MSD,SLP,AC/DELCO,Bosch,GMPP,Cntrfrce DF,Htchkiss,Susp.Tech,Lakewood,285's,Bilstein,Pro-kit,SLP,RK Sprt,A/Meter,Red Optima,Magnaflow S/S Tips,Hd Pins,Tint,Fire.Ex,[*4 Hot Rod Power Tours*]
  1. Question: 17's in front, 18's rear.
    By dneemorelos in forum Wheels and Tires
    Last Post: 02-04-2009, 07:43 PM
  2. 17's in the front and 18's in the rear
    By silplu83 in forum Wheels and Tires
    Last Post: 11-18-2008, 06:00 PM
  3. Front 275/35/18 Rear 295/30/19
    By Danny84 in forum Wheels and Tires
    Last Post: 08-27-2007, 09:26 PM
  4. Front and Rear QA1 shocks with front QA1 springs
    By 1BadCamaro in forum Parts For Sale / Trade
    Last Post: 08-09-2007, 04:16 AM
  5. Replies: 1
    Last Post: 06-15-2006, 06:15 PM
