Results 1 to 13 of 13
Thread: 17's in front, 18's rear.
01-30-2009, 04:19 PM #1GROUND KONTROL C.O.
- Jan 2009
- Dallas, Texas
PEWTER- 2002 Camaro Super Sport
Anyone know if theres any problems with putting 17's in the front and 18's in the rear??????? I'm pretty close to getting these rims and wanna know if anyone's run into any problems??
01-30-2009, 04:57 PM #2
Which wheels? What are the sizes? What kinda rubber are you planning on putting on them? Why not just run 18's all around??
01-30-2009, 05:59 PM #3GROUND KONTROL C.O.
- Jan 2009
- Dallas, Texas
zo6 2006 wheels
http://cgi.ebay.com/ebaymotors/ws/eB...m=220351592327
Don't know what kind of rubber yet.
01-30-2009, 06:12 PM #4
those shouldnt be a problem atall
01-30-2009, 07:16 PM #5
Those will work. The largest tire you can put on the 18 inch rim is a 315. But to put the 315 on you will have to shave the bump stop and hammer the inner wheel well a bit. It is not hard at all. I did it on my Z!
02-01-2009, 08:35 PM #6Crazy Canuck !
- Jun 2002
- Montreal, CANADA
make sure the tire sizes you chose have a very close overall diameter, so that ABS doesn't freak out.
here are the height for different tire sizes: http://www.ls1.com/forums/showthread.php?t=80679Eugenio_SS
02-02-2009, 04:28 PM #7
02-02-2009, 05:05 PM #8
Different diameter tires will rotate at different rpms to cover the same distance. Wheel speed sensors monitor tire rpm. When you use the brake the computer looks at the wheel speeds of all the tires. The computer will see the difference in wheel speed and interpret it at lock up and activate the ABS because two will be rotating fast than the other two..
02-03-2009, 08:40 AM #9
02-03-2009, 09:15 AM #10Senior Member
- Oct 2007
- Muncie, IN
00 TA PWTR, 98 VertTA NBM- 80 TA BLK, 80 Formula NBM
main reason i dont like staggered, is that you cant rotate front to back. imo, go same size wheels, same size tires all around. unless shes a strip/garage queen.
02-03-2009, 07:25 PM #11
02-03-2009, 09:00 PM #12Crazy Canuck !
- Jun 2002
- Montreal, CANADA
not necessarily... remember that over the wheel, there is the tire... and what counts is the overall diameter of the tire... ie, overall diameter = sidewall of the tire (touching the ground) + size of the rim + sidewall of the tire (the one on top of the wheel)
By looking @ the table I was referring to, you will see the overall size of the tire... and that's what count. If you have a taller tire, it will rotate slower than a small tire... and the ABS will thing one of them is blocking since it's not spinning as fast... and will act accordingly (not necessarily what you want)
02-04-2009, 07:43 PM #13
By silplu83 in forum Wheels and TiresReplies: 11Last Post: 11-18-2008, 06:00 PM -
Front 275/35/18 Rear 295/30/19
By Danny84 in forum Wheels and TiresReplies: 0Last Post: 08-27-2007, 09:26 PM -
Front and Rear QA1 shocks with front QA1 springs
By 1BadCamaro in forum Parts For Sale / TradeReplies: 1Last Post: 08-09-2007, 04:16 AM -
17s in front 18s rear?
By daveb91 in forum Firebird / WS6Replies: 12Last Post: 07-30-2006, 01:22 PM -
19's In the Rear 18's up front or 18's in the back 17's in the front?
By SAMO in forum GTOReplies: 1Last Post: 06-15-2006, 06:15 PM
