06-27-2006, 10:39 AM #1Junior Member
- May 2006
- California
Chameleon- 1998 Pontiac Trans Am
P0308 Cylinder 8 Misfire Detected HELP!
I just received the error P0308 - Cylinder 8 Misfire Detected the other day during heavy rain. I'm not sure if that had anything to to with it but my car is acting strange and I am not exactly sure what to do. My first thought was to change out the spark plug on cylinder 8 and see what happened, but does anyone have any other ideas? Am I doing the right thing? My plugs are only ~25-28K old and they're bosch platinum +4's. Thanks,
Jeff
06-27-2006, 10:43 AM #2Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
plugs, wire maybe loose, coil pack or injector.
06-27-2006, 11:26 AM #3Senior Member
- Jul 2005
- Jacksonville, FL
You're on the right track, go for the plug/wire first. Personally not a fan of bosch plugs, or leaving any plugs in for over 25K - JMO.
06-28-2006, 04:56 AM #4Junior Member
- May 2006
- California
06-28-2006, 04:59 AM #5Senior Member
- Aug 2003
- Honolulu HI
ngk tr55's if your N/A.
06-28-2006, 07:25 AM #6Junior Member
- May 2006
- California
06-28-2006, 07:37 AM #7Junior Member
- Sep 2005
- Idaho
Red- 2000 Camaro SS
Do the plugs. If that doesnt work, You are fucked. I got that same reading when my engine went to shit. Are your heads making a ticking noise? Loss of power? Engine shanking?
06-28-2006, 07:53 AM #8Senior Member
- Aug 2003
- Honolulu HI
Napa is usually pretty good about carrying them. No, he's not necessarily fucked as you put it. How did you get the code read? Here is what I suggest:
change plugs, if that doesnt work,
swap wire with a known good one. if the miss moves to the new cylinder, its the wire, if not, swap the coil pack with a known good one. If it moves to that cylinder, its the coil pack, if not, swap the injector with a known good one. If it follows..u get the picture. After you change the wire and its not the cause, put it back where it was. same thing for the injector and coil pack. Also, a list of mods and what you were doing with the car would help too. Ive seen misses happen with blown headgaskets too.
06-28-2006, 09:05 AM #9Senior Member
- Jul 2005
- Jacksonville, FL
If the parts store says they can't find it ask for NGK stock number 3951. They're MUCH cheaper than the +4's too.
Help: Raondom Cylinder Misfire
By scStormChaser in forum General HelpReplies: 1Last Post: 09-22-2014, 05:02 AM -
Help: cylinder misfire
By rhinojohn in forum Internal EngineReplies: 5Last Post: 12-04-2010, 01:38 PM -
Help: misfire detected
By rhinojohn in forum Internal EngineReplies: 8Last Post: 10-31-2010, 12:03 PM -
#7 Cylinder Misfire
By Jessica C in forum Computer & TuningReplies: 16Last Post: 08-27-2008, 03:50 PM -
p0305 cylinder 5 misfire
By ls1alltheway in forum Internal EngineReplies: 10Last Post: 03-24-2007, 11:21 PM
