Results 1 to 2 of 2
Thread: Raondom Cylinder Misfire
09-21-2014, 07:28 PM #1
Hey guys!
Having a strange thing happen. My 2001 SS Manual runs very rough for about 30 seconds to 3 mins of run time after cranking it up. However this only happens when the engine is warm and the car has been driven within about 3 - 4 hours ago. So when I first crank up the car in the morning after sitting overnight for 6hrs or more, it runs fine.
Once while I was trying to throttle the RPM up while it was running rough, i got a check engine light to flash over and over which threw a "random cylinder misfire" code. This only shows up if i try to throttle higher when its running rough. The engine completely smooths out after about 3 mins of driving. But if I shut it off for a few minutes, and crank it back up, it will run rough again for another few minutes.
Any idea of what would cause this strange behavior? If it ran rough all the time, id assume it was a bad plug, power pack, or timing. But the fact that it runs rough in the beginning only when the engine is warm makes me think something else is going on. Thanks for any replies, you guys are always helpful!
09-22-2014, 05:02 AM #2
Wow, what a weird problem. Have you checked fuel pressure with a gauge? Gotta start eliminating things to narrow it down.
Help: cylinder misfire
By rhinojohn in forum Internal EngineReplies: 5Last Post: 12-04-2010, 01:38 PM -
Complete cylinder misfire thread
By 98TransAmWs-6 in forum General HelpReplies: 1Last Post: 10-17-2010, 02:14 PM -
#7 Cylinder Misfire
By Jessica C in forum Computer & TuningReplies: 16Last Post: 08-27-2008, 03:50 PM -
p0305 cylinder 5 misfire
By ls1alltheway in forum Internal EngineReplies: 10Last Post: 03-24-2007, 11:21 PM -
P0308 Cylinder 8 Misfire Detected HELP!
By jdubbs928 in forum General HelpReplies: 8Last Post: 06-28-2006, 09:05 AM
