Results 1 to 3 of 3
    rique71
    tampa fl.
    1998 z28
    help with sounds
    hey guys hope someone can help me. a few days ago i changed the brakes on my z i put everything back the same way but i noticed that after i tightened the nut on the caliper it could still move back and forth and i also noticed that the brake hardware (if thats what it's called) that goes in the middle of the caliper was loose and i couldnt get it to stay properly in the center it would keep moving ,so i put it the caliper back really slow so the hardware wouldnt move but it still might of moved . well anyway ever since then i keep hearing a noise coming from the same side . sometimes it sounds like a thumping . question is could it be the caliper is loose ? i checked the screws and they were tight . hope i made sense with the stuff i wrote here thanks in advance guys.
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    If you are talking about the pins with the rubber boot on them, they are supposed to move back & forth. In fact, you should have gotten a special grease in your brake set for that very purpose.
    The torque for them is 31 Ft. Lbs.
    I'm guessing the "hardware" you are speaking of is your anti rattle springs.
    Get them on correctly. If you're having trouble with one, use an old one.
    rique71
    tampa fl.
    1998 z28
    ok im going to take them apart again
  1. Question: sounds different?
    By 01SsRacing in forum General Help
    Last Post: 11-25-2013, 07:09 AM
  2. this is what my car sounds like now
    By theslow00 in forum Western Members
    Last Post: 02-19-2008, 01:55 AM
  3. Tell me how she sounds!
    By Ryans99LS1 in forum Multimedia Section
    Last Post: 01-10-2008, 12:00 PM
  4. what sounds best??
    By edgeworthSS in forum Camaro / SS
    Last Post: 07-13-2007, 06:03 PM
  5. BAD sounds, need help
    By JonDaddy82 in forum Drivetrain
    Last Post: 01-21-2007, 07:06 PM
