Results 1 to 16 of 16
    ND2SPD 02T/AWS6's Avatar
    Jun 2006
    Atkinson, NH
    2002 Trans Am WS6
    How to turn off traction control???
    I have a 2002 Trans Am WS6 that doesn't have the TCS switch on the console in front of my shifter. Does anyone know what i can do to turn it off and on easlily????
    If you don't have the switch, I don't believe you have TCS.
    Junior Member shotzie's Avatar
    Eastpointe, MI
    2002 WS6 Trans Am
    If you don't have the switch in front of the shifter, you don't have TCS, which is rare
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    does a "low trac" light flash when you burnout in sand or on pavement, if it does, and you feel the gas pedal kick back at you, then you have ASR "tcs", if yes and u have no switch, you have a rare ass car
    Member 6sw00's Avatar
    N.Y
    2000 trans am ws6
    i believe that would be a mistake if u didnt have the switch but had tcs..
    Lost in Texas
    Custom Slate Blue
    99 B4C
    no switch, no traction control. If you need to further investigate look under the hood, if you have one cable going to the throttle body you have traction control, if you have two cables going to the throttle body you don't have traction control.
    Jun 2006
    Atkinson, NH
    2002 Trans Am WS6
    thanks for all the comments yeah i do get the low trac light when i do a burnout so i thought i had it but i don't have the switch but i'll figure out whether i have it or not then i'll see what i can do
    Aug 2000
    Indy
    Quote Originally Posted by oneBADDz
    correct
    Senior Member Zboner's Avatar
    cincinnati/northern ky
    99 SS
    look right above your battery man, there should be a small black box there and that is the traction control system
    Member TROYWS6X's Avatar
    New York
    1998 WS6
    Quote Originally Posted by 02T/AWS6
    If you can do a burnout easily, then you don't have TCS. Anyone with tcs that has tried to do a burnout and forgot to turn it off quickly remembers that it's on. The gas pedel "pushes" back, the engine bogs, and you look like a fool that can't drive. My brother had a TA without tcs and if I remember right, the light on the dash would still come on under low traction conditions.
    99 SS
    mine does not come on if im doing a burnout and i do not have TCS
    Lost in Texas
    Custom Slate Blue
    99 B4C
    Quote Originally Posted by Zboner
    I was gonna point that out. It will come on when sliding etc, but not during a burnout if you don't have traction control. If you have trac control it will come on when spinning though
    99 SS
    yup he is right
    Local Idiot Selah's Avatar
    Wilmington, De
    Cyclone Grey Metallic
    2005 GTO
    Why is not having TCS on an '02 WS6 so rare? I ask because I don't have it either.
    99 SS
    cause most of these cars came with that option, i dont have it either
    Jun 2006
    Atkinson, NH
    2002 Trans Am WS6
    yeah i checked into it and i guess i don't have it, o well one less thing to worry about , and hey i don't want it anyways cuz i go south for the winter and it's really not that bad in the rain
  1. Question: traction control will not turn off
    By 02transamce in forum Drivetrain
    Last Post: 01-03-2012, 01:29 PM
  2. cruise control with traction control
    By basballny2 in forum General Help
    Last Post: 06-16-2010, 11:57 PM
  3. Traction Control/asr
    By SilverFish in forum Camaro / SS
    Last Post: 08-14-2008, 08:59 PM
  4. Traction control
    By Al Hazz in forum Firebird / WS6
    Last Post: 05-25-2008, 09:20 AM
  5. Traction Control...
    By jamessr in forum General Help
    Last Post: 01-12-2007, 06:55 AM
