Results 1 to 2 of 2
    Junior Member SilverFish's Avatar
    Colorado
    Siver
    2000 Z28
    Traction Control/asr
    This is simple question for pretty much anybody on here. My car had some wiring problems from the previous owner. The button for Traction that Says ASR above the radi has a light in ? When I press it, the light goes off. There is nothing on the dash at all - I am assuming that in the cluster bulb is out or something. The question I have is how do I make sure the traction control is OFF ? Should the ASR button be lit up or not ?
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    When you press the switch and the light goes off then the ASR is off as long as the engine is running. If you turn the engine off you'l have to deactivate ASR again.
    If the light in the instrument cluster doesn't come on (yellow letters stating ASR OFF) it may just be a bulb. If it doesn't come on briefly when you start the car then it's most likely the bulb.
    Need to be sure? Do a burn out. Foot brake for an A4 or slipping the clutch on launch for an M6 should get the tires spinning.
  1. cruise control with traction control
    By basballny2 in forum General Help
    Last Post: 06-16-2010, 11:57 PM
  2. traction control
    By racer426 in forum GTO
    Last Post: 12-16-2008, 07:04 PM
  3. traction control
    By jordanvb in forum General Help
    Last Post: 12-12-2008, 01:48 PM
  4. abs and traction control
    By davidz28guy in forum Corvette
    Last Post: 08-12-2006, 08:28 PM
  5. Traction Control
    By daryl.l in forum Firebird / WS6
    Last Post: 03-05-2006, 01:05 PM
