Results 1 to 20 of 23
    Exclamation tap tap tap tap tap tap tap tap tap tapping
    here's the scenerio:
    car club was in a parade, naturally revving engines/making noise. I probably went to 6500 and 7000 regularly [imagine doing that about 90 times over the course of a mile] Pulled into a parking lot afterwords to hear i'm the only car with a really high pitch tapping / pinging noise coming from the engine....shut off the car, lifted the hood to cool it off for a good 45 minutes. Turned it on....noise is still there. Oh, someone said that since i'm running fully synthetic oil that could be the problem?
    What'd i do? What do i do? what's it gonna cost?
    SShArK>
    Guest
    maybe a pushrod?
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    6500 to 7000? I hope you have an aftermarket drivetrain.
    Other wised you floated the valves and they tapped the pistons.
    Bent valves.
    local car guru says it's a lifter. anyone know if an LT1 lifter can replace an LS1 lifter?
    Aug 1999
    No Where
    Stock valvetrain?
    Member sscrazy's Avatar
    Warren MI. (detroit area)
    00 camaro ss
    sounds like a bent pushrod or a bent valve tapping the piston, I would pull the heads off and inspect before you run the car again.
    Quote Originally Posted by Ed Blown Vert
    Stock valvetrain?
    yes, stock everything
    Member keliente's Avatar
    Charlotte, NC
    99 Firebird Formula
    It sounds like a pushrod to me. It's a light tap/tick noise that increases with RPM...you'll also notice a loss of power over ~5k rpms. I bent a couple a few months ago when I shifted from 3rd to 2nd @ 100mph...whoops!
    It is a very easy fix. Remove emissions crap, coil pack brackets, valve covers. Remove rocker arms and the pushrods pull right out. When you roll them on a flat surface you'll notice which are bent - they won't roll smoothly. New pushrods are very cheap. When you reinstall don't forget correct torque specs & loctite on the rocker arm bolts.
    kelli, my savior! thanks-yes thats what it does too, increases with rpm
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    Whoa...! Don't do that kind of revving with the stock valvetrain.
    Aug 1999
    No Where
    Quote Originally Posted by dipherentdesign
    Ok, its either bent pushrods or valves.
    Don't rev it over 6k on a stock valvetrain. You probably aren't making anymore power over 5800 anyways.
    Quote Originally Posted by keliente
    Aftermarket are cheaper than the GM ones.
    If it is only one pushrod bent, PM me. I have one still in wrapper from GM.
    If you go with aftermarket pushrods, they won't bend to save your valves. If you go around revving like that you will pop a valve stem with hardened pushrods.
    I wouldn't do revving like that WITH an upgraded valvetrain. You are gonna break something doing that. Overall, try not to free-rev.
    Lowered, HID's, tinted.
    R.I.P. LS1 LS1Power06's Avatar
    817, Texas
    03 Terminator
    6500-7000 RPMs? did u mess with the rev-limiter with a programmer or something because to the best of my knowledge it wont let u rev that high from the factory right?
    Senior Member Zboner's Avatar
    cincinnati/northern ky
    99 SS
    Quote Originally Posted by LS1Power06
    yes he did.
    anybody know where i can get stock pushrods OVERNIGHTED to me?
    Aug 1999
    No Where
    I have a set, but don't think I can get them out tomorrow.
    00 camaro ss
    I have a set of used ones out of my ss. also I have a set of rockers. Let me know if you want them i will part with them cheap , make an offer
    Quote Originally Posted by sscrazy
    i'll consider those rockers...don't know if we'll need them jsut yet.
    I escaped DC
    Anchorage, AK
    How were you able to rev it that high without hitting the limiter?
    *EDIT* My bad, completely missed about 5 posts there.
    2001 WS6, M6, Black/Black
    !Baffles to sealed airbox, MTI lid with K&N, Bo White ported TB, Pacesetter coated LTs, TSP catted-Y, Flowmaster catback, Pro 5.0 shifter, BMR STB and SFCs
    343hp and 357tq before ported TB on HPTuners
    OK HERE'S THE UPDATE!!!!
    so my buddy an i crackopen the valve cover on the passenger side to see that rocker #2 is EXTREMELY loose. So we inspect the pushrod; it's fine. Inspect the rocker; it's fine...oh shit...gotta keep digging-it was a broken LIFTER! it took us like 6 hours of unscrewing, unbolting and digging....we had to take off the manifold covers, the intake and the headders to finally reveal a single broken lifter. It sucked that we had to do all that but it was better than being charged 700+ in time/parts to have the pros do it.
    i've learned a lot about this engine just in doing all of this...
  1. Help: tapping noise!
    By godless-phoenix in forum Firebird / WS6
    Last Post: 10-15-2010, 07:52 PM
  2. Question: tapping when stopped
    By justinmc978 in forum General Help
    Last Post: 09-17-2009, 08:15 PM
  3. Tapping
    By flipsutter in forum V6
    Last Post: 07-24-2009, 10:34 AM
  4. Tapping Noise
    By David Ray in forum General Help
    Last Post: 05-27-2009, 05:27 PM
  5. Tapping sound...PLEASE HELP!
    By RAWPWR3 in forum General Help
    Last Post: 11-16-2005, 02:19 PM
