Thread: Tapping
    Member flipsutter's Avatar
    May 2008
    Arkansas
    1999 Firehawk
    Tapping
    Good Morning,
    Well once the transmission in my Firehawk is put back in my next project is going to be that damn ticking noise coming from the drivers side valve cover on my V6.
    How hard would it be to crack open the valve cover and see what is causing the issue? Would I be able to tell if its a bent pushrod or a broken rocker arm or something along those lines by just looking at it? I swear its the the first cylinder on the right but I'm not 100% sure.
    Member NoscamaroSS's Avatar
    Durant, Okla
    2002 Camaro
    I bet it is a ticking lifter. My suggestion would be to get a can of seafoam and put half the can in the oil, then start the car and let it run through the motor. I would probably put about 10-20 miles on it with the seafoam then change the oil. This should fix your problem, plus its alot easier than pulling the valve cover off.
    02 Camaro
    PRC Stg 2.5 5.3's, Futral F14, PP Typhoon intake, True duals, Performabuilt tranny, & 3500 convertor, HSW plate kit.
    *Old Time* 10.90@ 125mph
    scottsboro, al
    2001 v6 camaro
    Yea lifter tick is a very common occurrence with the 3.8. Try the seafoam, and if that doesn't work pull the valve cover to make sure its not a loose rocker or bent pushrod. if those are in the clear a partial collapsed lifter it is.
    May 2008
    Arkansas
    1999 Firehawk
    Thanks guys.
    I'll check that once I get my V8 back. I so can't wait!
    Pittsburgh
    2008 Hummer H3
    Check under the exhaust manifold for carbon track @ the gasket too. A slightly leaking manifold gasket will tick sometimes too. Good luck.
  1. Help: tapping noise!
    By godless-phoenix in forum Firebird / WS6
    Last Post: 10-15-2010, 07:52 PM
  2. Question: tapping when stopped
    By justinmc978 in forum General Help
    Last Post: 09-17-2009, 08:15 PM
  3. Tapping Noise
    By David Ray in forum General Help
    Last Post: 05-27-2009, 05:27 PM
  4. Tapping sound...PLEASE HELP!
    By RAWPWR3 in forum General Help
    Last Post: 11-16-2005, 02:19 PM
  5. tap tap tap tap tap tap tap tap tap tapping
    By third_shift|studios in forum Internal Engine
    Last Post: 09-10-2005, 05:15 PM
