Thread: weight distribution question
06-14-2006, 09:32 PM #1
If i remove the backseat, belts, spare and jack, will the weight distribution change enough to negatively affect handling? Has anyone tried this?
06-16-2006, 11:25 PM #2Junior Member
- Feb 1999
- Stockton. Ca.
White red- 98 SS 17 Grand Sport
I have autox my car with the all that stuff in my and without. I couldnt tell a difference, but weight is the enemy and less you have the better. The car will brake, accellerate faster and probably will handle a little better when doing quick transitions.(slalom)
What might help is to move the battery to the rear of the car where the spare tire goes.
06-18-2006, 06:54 PM #3
If you're using the car to autocross and you're going to remove the seats I'd say that you need to get it on some scales to see where the weight is at. What you want to get is a 50/50 weight distribution on the car. If I remember correctely I think stock F-bodys have about a 60/40 ratio out of the factory. It may be a little less but I think you're dealing with more weight in the front. Again, if you have access to car scales and can weigh the car at all four tires you'll be able to get an idea what you need to do with it. It also depends on what class you're running.....if you're running FS you cant even take the seats out........gotta run it like it stands with the exception of tires, shocks, and front sway bar change.......
07-09-2006, 11:44 AM #4
07-09-2006, 11:48 AM #5
FWIW:
I did remove all the dead weight in back and after removal and weighing, I get to the nearest 5 lbs:
Front: 2080 (57%)
Back: 1570 (43%)
Total 3655 (100%) - includes me (@215lbs), 1/2 tank, and the mandatory G-tech pro and legal paperwork.
So it looks like a stock is even closer to 50-50 than you thought.
Last edited by Raven98Z28; 07-09-2006 at 11:53 AM. Reason: I'm a dumbass and calculated backwards...
THEN: 98 Z28 A4 2.73 FRA STB SFCs LCA Relocators Lowering Springs DAPHR SLP Bilsteins Descr. MAF EGRCut-off Lid Eradispeeds - Daily Driver includ. 3 yrs on the German Autobahn!
NOW: '02 WS6 M6 LOTB BMR STB, SLP bolt-in SFCs, !spare/jack, SLP lid, Battery Relocation
07-10-2006, 05:53 PM #6
Weight distribution hitches
By pajeff02 in forum GM TrucksReplies: 0Last Post: 06-16-2011, 07:15 PM -
question about thunderform's and car's weight
By third_shift|studios in forum Stereo and ElectronicsReplies: 3Last Post: 05-07-2007, 02:31 PM -
LS1 weight length question
By metric_thumbs in forum General HelpReplies: 12Last Post: 05-05-2007, 02:59 AM -
Weight removal question
By Raven98Z28 in forum Drag RacingReplies: 7Last Post: 06-21-2006, 10:11 PM -
Weight Question
By SailorZ28 in forum General HelpReplies: 2Last Post: 03-21-2006, 12:14 AM
