Thread: $5000 and what to do
06-14-2006, 11:51 AM #1
Today i was offered $5000 for my quad. Before i got my car my quad was my life and now im kind of losing intrest in it. The quad is prolly worth 4500 and i wasnt even looking to sell it. But this brought light upon my eyes today when the guy came up to me. Im pretty sure im going to sell it to him...Ive rode the thing 3x in the past 4 months. I dont have the time or $. So i figure $5000 would look really nice under my hood. What im asking is some general opinions as to what i should buy...I have some ideas im toying around with but im not really SET on anything. Heres everything on my car, performance wise.
Crane cam(Small)
Crane roller rockers
Crane springs and ti retainers
Light Port n polish of heads
Borla CB
SLP lid and high flow filter
180* thermo
TB bypass
No emissions at all
Groty LT
3" mufflex catless y w/ merge
Stage 2 clutch
255lph fuel pump
Short shifter
---note---im looking to sell my borla, y pipe and headers. Or ill trade headers for hooker or similar to work with true duals (ill know if theyll work if you can send pics)
Im most likely going to take $2000 of it and put of it to the side because god only knows how much longer my rear is going to last me. Heres some of my ideas.
-first off get updated master and slave cyls.-200
-500 more to the side for a pro dyno tune once i get w/e im getting
-drag or street slicks wouldent be a bad idea on a spare set of rims but i have no idea what the prices are on them
1.monster cam (trex or similar or custom grind)-500, will i need new springs etc for this?
2.heads-700 to 2400
3.150 wet shot w/ everything-1000
4.get tb ported and polished-75
5.ls6 intake-250 or bbk-420
6.Moser 12 bolt w/ 410s-2000
7.42lb injectors-300
8.UD pulley-200
9.Adj torque arm-300
10.3-point bolt on or weld on subframe connectors-300
11.13lb flywheel-230
-i figure i can also make a few $ back with the old parts ill no longer need
-dont consider labor into any of this. Everything i can do or have done for me at no cost other then the tune. I have access to a lift and basically every tool on the planet whenever i need it and my friends dad welds for a living. My uncle is a mechanic for gm so im set as far as that stuff goes. Kind of a long post but oh well...let me hear your opinions!!! thanks
06-19-2006, 09:34 AM #2
in my opinion i would do motor work, rip out that ls1 and put a stroker kit in it, i havent done the research yet so i don't know what kits are out there an which ones are the best but doing engine work instead of bolt ons will give your car more power and reliability
i would go with having the block bored with oversized pistons and stroker crank and some high flow heads, if you do work yourself you should be able to get all the parts plus having the block machined
with all the bolt-ons you have already you should have one bad ass car after motor work and tune
if not motor work, i would get the 12 bolt rear end with some fat tires and 17 inch wheels
06-19-2006, 09:42 AM #3live fast, die young.
- santa ana
metallic blue- 1969 camaro
im with silverZ28.... if ur lookin for more power, then do the stroker, make a 383 LS1, thatll give u the most power for your money, either that or throw on a turbo kit, lots of power, but u sacrafice a little bit of ur engine life, either way ull make a fast ass car even faster
06-19-2006, 10:04 AM #4
i had thought of getting it bored. its still in my mind too but i didnt think 5000 was quite enough for everything. So you guys think i can get my block bored (im pretty sure i can get it done fairly cheap), high comp pistons, forged rods, a forgred crank, heads/cam package and all the other small stuff for 5000? And if i do this im still out 2000 for the rear im going to NEED after the 383. Also, why not go all the way with a 408? Is there a reason as to why this would be a bad idea? Thanks
06-22-2006, 11:02 AM #5
if you take the motor out and tear it down , clean it and then have a shop install the bottom end you should be pushing it price wise, maby a 2000 personal loan or just save for a year, do everything perfect , if you are going th use it as a daily driver the go with a smaller stroker kit, if not , up the cubes, if you don't want to spend more that 5000 the go with a 12 bolt rear 4.10 and a head and cam package, with some nice fat tires, even with your stock bottom end you should pull high 11's or low 12's depending on climate
thats what i would do with 5000
87 443, 403 big block, $5000, NJ
By ShadowHawk in forum Vehicles For Sale / TradeReplies: 0Last Post: 05-27-2009, 10:12 AM -
If you had $5000 to spend on a 94 Z28....
By hix5000 in forum Camaro / SSReplies: 18Last Post: 05-22-2009, 02:32 PM -
WTB: LS1 Car $5000 or under AND WTS: 94 Formula
By tford0688 in forum Vehicles For Sale / TradeReplies: 0Last Post: 01-28-2009, 07:47 AM -
$5000 to spend, what to do
By DMash1080 in forum Internal EngineReplies: 40Last Post: 06-27-2007, 09:15 PM -
looking for an ls1 for around 5000
By chevy_muscle in forum Vehicles For Sale / TradeReplies: 0Last Post: 02-28-2006, 05:39 PM
