Results 1 to 3 of 3
Thread: A little AC Delco Battery FYI
06-12-2006, 04:17 PM #1Space Cadet
- Nov 2005
- Port St. John, FL
Red & Dk Gray- 2002 WS6, '08 G8 GT
Well I'm posting this here more for info than anything else, not a request for help. Most of you have probably heard about this already but for those who have not. . .
Finally fell victim to the the dreaded AC Delco Battery curse. On way home from work this evening, stopped by grocery store, everything was fine, came out and she was dead
Long story short, known problem with AC Delco batteries. Positive side-post terminal broke off. Not corroded or anything like that, just broke, damn things are just glued in
! Able to get broken terminal off cable no problem!
Same type of thing happened to my Moms '98 Daytona edition GTP last year. Original factory battery, 7 years old, finally died and the terminal broke off while he (my dad) was trying to change it out. Unfortunately he had to have the entire positive cable replaced at the dealer. Couldn't get broken terminal off at all. . .neither could the mechanic
Anyway, just a little FYI for those of you running AC Delco Batt's.
WS6 has a new Optima now!
http://i28.photobucket.com/albums/c2...shutlle101.jpgGo DISCOVERY STS-121 Return to Flight!
http://mediaarchive.ksc.nasa.gov/
06-24-2006, 01:41 PM #2Junior Member
- Jan 2006
- Lake Worth
Arctic White- 2001 Camaro convertible
I haven't had a post fall off yet, but I did have a leaking Delco battery. Apparently, due to the way they are manufactured, if you bolt on the terminals too tight, the post kind of separates and you have a leak. Fortunately, GM replaced it for me under warranty and my new Delco battery has been fine so far. It's about 3 years and going now...
07-09-2006, 05:51 AM #3Member
- Virgina
Black- 98 Trans Am
Mine had corroded UNDER the red positive rubber insulator on the cable, and wasn't visible unless you skinned it back!!! I replaced the battery after cleaning the "visible" corrosion, and a month later when driving, all of a sudden the engine would stumble...almost cut off...all the dash lights would flash on and off...the radio would make a loud screech, then go into LOC mode...and all the gauge needles would swing to the right and just vibrate...all this at the SAME TIME for about 5 seconds, then eveything would go back to normal! This would happen at random, and was driving me INSANE because when it wasn't doing it, you couldn't find ANYTHING wrong! It threw NO codes, new batt and alternator checked out okay when tested...couldn't find ANYTHING...until...something told me to "skin back" that red rubber insulator on the POSITIVE batt cable and BAMM!!...corrosion was CAKED and PACKED underneth that thing from the leak from the old Delco!! You would never even see it unless you pulled it back!! After taking it off/apart and cleaning the cable under it really good, the problem disappeared!!
AC Delco Battery
By justhend in forum General HelpReplies: 8Last Post: 07-25-2013, 09:06 AM -
AC Delco Battery warranty?
By sg5492 in forum General HelpReplies: 1Last Post: 09-20-2011, 09:03 AM -
AC Delco 9mm wires & AC Delco Iridium plugs
By NitrOmm in forum External EngineReplies: 9Last Post: 07-15-2009, 09:04 AM -
Original Delco Battery Question
By sg5492 in forum General HelpReplies: 2Last Post: 06-06-2009, 10:03 PM -
Battery trade in dfw My Optima for your battery
By Lucky 13 in forum Parts For Sale / TradeReplies: 2Last Post: 04-10-2009, 04:33 AM
