Results 1 to 11 of 11
    Louisville, KY
    1999 Trans Am
    Plug change... now problem!
    I started to change my plugs last night and got half way done (replaced all plugs on drivers side) and decided to wait until today to replace the rest of them. This morning I jumped in the car to run to the grocery and the car ran fine on the way there. But on the way back I decided to get in it a little bit and the car is missing badly above 4500 RPM at WOT. I took a detour to try it out again and it does the same. Before you ask I did not replace the wires and I used NGK Iridium plugs. I falied to use any dielectric (sp) grease on the wires. Does this sound like a plug wire problem? The car ran fine before I worked on it last night, just had a little hesitation, but still ran hard. Now it is running like sh!t. I checked and rechecked all wires before I fired it up this morning and everything appeared to be in order. The car runs perfect during normal driving but once you get in it and get past about 4500 RPMS it cuts out like a b!tch. Should I pull the wires off again and put some grease in them, could this be the problem? The car did not set an SES light, which I thought was odd considering how it was running. All help is appreciated!
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Boot grease has no purpose other than allowing for easy removal and perhaps to help keep moisture out.
    Things that come to mind in this scenario are that you may have a bad plug even though they are new, gotten antisieze on the firing tip of one or more plugs, pulled loose a wire from an injector, broken one or more ignition wires by not using boot grease on a prior install, pulled a connector off and not replaced it, didn't gap plugs correctly, just to name a few.
    Good luck.
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    Most likely it is a wire problem.
    did u check all of the plug gaps? sounds like spark is blowing out under accel. this can happen with too wide of a gap
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    Make sure the wires double click on the coils and single on the plugs...check the gaps like previously stated
    Quote Originally Posted by SeVeReDiStOrTiOn
    +1
    I bet you don't have a wire on all the way or you damaged one pulling them off the old plugs.
    Impounded YoMommasTA's Avatar
    ne pa
    replace ALL the plugs then try it again...running on half new and half old is gonna freak the computer out terribly.
    Louisville, KY
    1999 Trans Am
    Quote Originally Posted by 90zcrex
    Gaps were fine?
    Louisville, KY
    1999 Trans Am
    Quote Originally Posted by 0rion
    +1
    This is a possibility, I did have to get rough with one of them.
    Louisville, KY
    1999 Trans Am
    Quote Originally Posted by YoMommasTA
    Why would old and new plugs cause a problem? Not questioning you just wondering why?
    Louisville, KY
    1999 Trans Am
    I need new wires anyway and I will place a order for some MSDs very soon. I'll post up and let everyone know what I find. Thanks for the help!
  1. WS6 Spark Plug Change
    By kheflw in forum Firebird / WS6
    Last Post: 02-21-2012, 12:52 PM
  2. Spark Plug change
    By Vince from Shamwow in forum General Help
    Last Post: 06-11-2011, 12:10 PM
  3. Plug and Wire Change
    By Raoul-Duke in forum General Help
    Last Post: 07-14-2010, 10:34 AM
  4. spark plug change problem
    By ls1wallen in forum External Engine
    Last Post: 02-25-2010, 01:05 PM
  5. Plug Change Inquiry
    By ss~zoso~ss in forum General Help
    Last Post: 08-09-2006, 01:39 PM
