Results 1 to 3 of 3
    maine
    2000 ws6
    How to tell bad torque arm bushing?
    I was under my car today because ive been hearing light clunk while on the lightly stepping on the gas or letting off the gas. I was thinking it could possibly be the u-joints but could feel any play in there and dont really know how to see if theyre bad anyways?
    The trans mount has been replaced with a poly because the stock one broke so i know its not that. I could wiggle the torque arm in the mount and good 1/8th of an inch up and down. I dont know how tight this is supposed to be and am wondering if it could be causing the sound? The bushing has a slit in it on the bottom right which looks kinda like it suposed to be there but is it?
    Also i could feel very slight play in the output shaft of the tranny by pushing it up and down, is that normal?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by got-a-ls1
    look for play where the + part of the u-joint goes into the cups that hold the needle bearings.
    1/8" is ok. not great. check the bolts that hold the torque arm to the rear. also, looks for cracks in that same area.
    yes, normal.
    maine
    2000 ws6
    so whewn checking the ujoints should i look by turning it or push the driveshaft up and down? because i turned the driveshaft by hand and didnt notice any obvious play
    thanks!
  1. Question: Torque arm bushing
    By Firebirdformula99 in forum Suspension and Handling
    Last Post: 06-24-2011, 12:52 PM
  2. Torque Arm Bushing?
    By robert 98 in forum General Help
    Last Post: 07-02-2009, 08:45 AM
  3. Help: Torque Arm Bushing
    By Finally in forum Suspension and Handling
    Last Post: 04-19-2009, 08:09 AM
  4. Just Installed New Torque Arm/ Bushing
    By CDS98Z28 in forum Drivetrain
    Last Post: 10-03-2006, 03:52 PM
  5. Upper Control Arm Bushing Torque
    By AFASTYZFR1 in forum General Help
    Last Post: 09-27-2006, 11:27 PM
