    Nov 2010
    orlando fl
    firebird formula 99
    Torque arm bushing
    I changed my motor mounts and transmisson mount to polys and i have a hard banging when it shifts and when it down shifts could it be the torque arm bushing going bad to it feels like its banging around the transmisson when im driving its like a thump like theres slack in the drivetrain
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Did you do the transmission mount relocated?
    Do you have pics of the work done?
    Nov 2010
    orlando fl
    firebird formula 99
    No I just took out the stock mount and put the poly one from jegs in we can relocate the mounts?
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    Quote Originally Posted by Firebirdformula99 View Post
    I'm not sure what could be causing the additional noise, as these relocation kits do make it quite a bit noisier.
    Here's a link for manual setup:
    http://www.umiperformance.com/catalo...roducts_id=201
    I know poly bushing make transmit more noise, but you could try swapping back out to see if that eliminates it (just the TA one). Hopefully someone will chime in with a better idea than mine.
    Member TransAmX2's Avatar
    Jun 2010
    Central Florida
    Navy Blue, Dark Cherry
    98 M6 TA, 87 A4 TA
    KM i think you might have misread, if I understand the OP correctly he did motor mounts and tranny mounts not torque arm.
    OP If your new motor and tranny mounts are installed correctly (I'm sure they are) then I'd say the bang and slack you feel uppon accel and decel are almost guaranteed to be the torque arm, most likely the front bushing but do go and check the back where the bolts go through for any oblong wear marks or damage to the torque arm itself, this is where mine decided to fail.
    I would personally either get a relocation bracket to get the torque arm off the transmission (and a new bushing) or get a tunnel mount/crossmember mount torque arm.
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    Quote Originally Posted by TransAmX2 View Post
    I was just double checking if he relocated the transmission mount, which can also relocate the TA. I'm wasn't sure if it was still in the stock location. Hard to diagnose these without being there.
    +1 for your suggestion! Could be a possible culprit as well, got to love the stamped suspension! It should all be looked over, as the solid mounts could have a been the straw that broke the camels back.
    Nov 2010
    orlando fl
    firebird formula 99
    Thanks guys I just wanted to confirm it was that before i bought it
  1. Torque Arm Bushing?
    By robert 98 in forum General Help
    Last Post: 07-02-2009, 08:45 AM
  2. Help: Torque Arm Bushing
    By Finally in forum Suspension and Handling
    Last Post: 04-19-2009, 08:09 AM
  3. Just Installed New Torque Arm/ Bushing
    By CDS98Z28 in forum Drivetrain
    Last Post: 10-03-2006, 03:52 PM
  4. Upper Control Arm Bushing Torque
    By AFASTYZFR1 in forum General Help
    Last Post: 09-27-2006, 11:27 PM
  5. How to tell bad torque arm bushing?
    By got-a-ls1 in forum Drivetrain
    Last Post: 06-11-2006, 08:16 AM
