06-08-2006, 03:22 PM #1
Underdrive Crank/Alternator Pulley Question
If I opt to install an underdrive pulley on my LS1 2000 Z28 will I see an increase in RWHP? Is it woth the $$$ and which do you consider the best. Thanks
06-09-2006, 02:32 PM #2
you will see about 8-10 rwhp out of an under drive pulley set up. is it worth the money?? up to you. do you want to get all the hp you can? then, yes. is $100/hp a good buy? not really.
06-09-2006, 03:12 PM #3
Good point on the $$$ to HP ratio. I have a lid, smooth bellows, K&N filter and Hooker CB. I was attempting to add a little extra without going internal or changing up my exhaust. Thanks for the reply.
06-09-2006, 04:17 PM #4
Maybe I'm off, but isn't an underdrive pulley only like $200? And if that is the case, you'd be talking about $20/hp. Not the greatest deal, but once you're maxed on bolt-ons and too poor for power adders or cam/heads, it doesn't look too bad.
Btw, there's still a list of things to do before you hit serious money. Headers (which aren't cheap) should be a priority, ported TB with coolant bypass, gears, and a tune will all help, some a lot more than others.Last edited by ProwlerZ; 06-09-2006 at 04:20 PM.
She's baaaaaccccck...
'02 Z/28 M6 Hardtop
06-09-2006, 04:22 PM #5Slow'er'Ass
- Thornton, CO
If you gain 8-10 RWHP for a $200 pulley...you aren't doing bad in my opinion.
I did the ASP underdrive pulley (crank only) on my stroker. No idea what gains it gave me. Didn't have a before/after dyno.
I do know I had enough power to require a solid tensioner with that pulley though.2008 Trailblazer SS
Lowered, HID's, tinted.
06-10-2006, 08:30 AM #6
Originally Posted by ProwlerZ
i was using a for instance on the dollar/hp thing.
06-13-2006, 01:58 PM #7Junior Member
- Feb 2006
- Charlotte, NC
NBM- 2002 Z28
and that's pretty much the ratio for headers.
$600/~20HP = $30/hp
06-15-2006, 12:36 PM #8Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
even if you dont notice a big gain in hp, you will notice faster revs...that helps out alot. You should only see 8-10 yes, but again, with these motors its not about what one mod does, but what the combination does
06-19-2006, 03:13 PM #9ILL SKEET IN YUR EYE
- Jun 2006
- bay area california
black on black on black- 02 z28
I HEARD GOODTHINGS ABOUT THE SLP PILLEY 25% UD CUZ IT HAS EXTRA MATERIAL ON IT SO THE BELT WONT THROW. IM GONNA GET THIS ONE SOON. IVE HEARD MANY TIMES OF OTHERS WITH LS1 UD PULLEYS LOSING BELTS. F THAT ESPECIALLY IF YOUR OUT OF TOWN WHEN IT GOES. THAT WOULD SUCK
06-19-2006, 04:38 PM #10SLP makes a great pulley!
Originally Posted by breakparts
06-20-2006, 06:00 AM #11
I use a march pulley and saw a 2mpg increase in fuel economy on the HW
06-20-2006, 07:07 AM #12
SLP Underdrive Pulley
Ordered a SLP F-Body Underdrive Pulley (P/N SLP100221) from http://www.ls1speed.com/ for $213.16 and no S&H. Best buy I could find and a savings compared to other sites. Found the Gates belts on Amazon.com for $53.97 to the door.
WTB: Lid, muffler, Underdrive Crank Pulley
By 98 4mula in forum Parts Wanted / TradeReplies: 0Last Post: 02-04-2008, 02:09 PM -
underdrive crank pulley?
By stangslayer98 in forum External EngineReplies: 5Last Post: 10-15-2007, 10:52 PM -
Underdrive Crank Pulley Question
By 89LX in forum External EngineReplies: 2Last Post: 06-10-2006, 08:52 AM -
Underdrive Crank Pulley Does What?
By Ponti-MANIac in forum External EngineReplies: 4Last Post: 02-17-2006, 05:09 PM
