    N/A nitrously aspirated stangslayer98's Avatar
    miami,fl
    1998 trans am
    underdrive crank pulley?
    today while cleaning the engine bay i noticed that my underdrive pulley looked like it was wobbly....but under slight throttle it appears to smooth out. my question is has anyone else done an install using an impact gun and the same old bolt that was on the factory pulley.
    You can't re-use the factory bolt. They are torque to yield, so after they have been used once, they are done. Spend $6 and buy a new one at the stealership.
    Painted manta stripe
    Junior Member Hamrhead's Avatar
    Wisconsin
    2000 Camaro
    Just get the ARP one and never worry about it again.
    Marylandistan
    2001 Trans Am (sold)
    How can you tell it's wobbling at idle? The engine is shaking a lil anyway. I think that's what you're observing.
    Wisconsin
    2000 Camaro
    Be careful with your statement as some people insist that you CAN reuse the bolts and it is just a myth! Ignore manufacturer recommendations, the wobble is your mind playing tricks on ya.
    how many psi was your impact wrench? That bolt gets torqued to a phenominal amount of torque. I used the ARP bolt and after reading many conflicting torque numbers I settled on 200 ft lbs I think it was. 200 or 240 or something like that. Basically as much as I could give it. I did get the wrench to click without using a pipe.
    I know the stock one is torqued then backed off and torqued again then stretched but I think the final torque numbers are up there even on the stock bolt.
  1. Which belt with 10% underdrive crank pulley, stock
    By Blue28 in forum General Help
    Last Post: 09-22-2009, 11:13 AM
  2. WTB: Lid, muffler, Underdrive Crank Pulley
    By 98 4mula in forum Parts Wanted / Trade
    Last Post: 02-04-2008, 02:09 PM
  3. Underdrive Crank Pulley Question
    By 89LX in forum External Engine
    Last Post: 06-10-2006, 08:52 AM
  4. Underdrive Crank Pulley Does What?
    By Ponti-MANIac in forum External Engine
    Last Post: 02-17-2006, 05:09 PM
