Thread: window switch
06-08-2006, 11:15 AM #1Junior Member
- Oct 2005
- MN
- 00ss,85roc vert89roc 91rs
window switch
Are there any recomended window switches??
maybe Cheap and easy to install?
06-08-2006, 12:23 PM #2
check with matt @ HSW www.harrisspeedworks.com i run a FJO dual stage window switch. more than what you need. you need a single stage window switch. really easy to use.
06-08-2006, 02:22 PM #3Member
- Warminster, PA
The BMN window switch is nice as it has a first gear lock out option:
http://www.harrisspeedworks.com/shop...cat=308&page=1
Matt
06-09-2006, 08:09 AM #4Ratdaddy07Guest
O.K I know this is probably a dumb question but what exactly does a window switch do? I assume it only allows nitrous to be on within a certain RPM range but you know what assuming will get you. Also, do any kits come with them and if not can they be added to any kit?
06-09-2006, 08:11 AM #5Member
- Warminster, PA
You have it, they will only allow the N2O kit to be active while in a pre-set RPM range (or window). I'm not aware of any kit that includes one, but any N2O kit can use a RPM window switch.
Matt
Originally Posted by Brian Hensgens
06-09-2006, 08:40 AM #6
06-09-2006, 08:44 AM #7Ratdaddy07Guest
Thanks, sounds like a no brainer for a 6 speed car.
MSD Window Switch
By Whiteboycntdnce in forum NitrousReplies: 3Last Post: 11-01-2007, 09:33 PM -
Camaro Window Switch/1le window/power lock delete kit
By Marc1130 in forum Parts For Sale / TradeReplies: 0Last Post: 03-12-2007, 11:05 PM -
Window Switch FS
By juiced99ws6 in forum Parts For Sale / TradeReplies: 0Last Post: 04-04-2006, 04:04 PM -
RPM window switch, and WOT switch
By corvettelover in forum Parts Wanted / TradeReplies: 1Last Post: 12-02-2005, 12:21 AM -
Window Switch Help
By Richard Nock, Jr. in forum NitrousReplies: 12Last Post: 08-25-2005, 05:25 AM
