Thread: MSD Window Switch
10-30-2007, 03:15 AM #1
MSD Window Switch
Looking to install a window switch to make the nitrous system a little bit safer and more automated! Ive heard the MSD window switch is the way to go w/ our ignitions... Is this correct?
10-30-2007, 04:04 AM #2
it's one of many that you can use.
10-30-2007, 09:46 AM #3Awaiting Activation
- Sep 2007
- Colorado
Black- RIP S4 06Tbss
Thats what I have, MSD is a good way to go.
11-01-2007, 09:33 PM #4Junior Member
- Dec 2005
- Hendersonville, NC
Black/Black- 1999 FRC
A window switch is very helpful in keeping things safe. It'll prevent spraying below certain rpm's which helps avoid backfires and fuel puddling in the intake. It also stops spraying at certain rpm at the top too. Thats useful if you miss a shift and also shuts spray off before you hit the rev limiter. Rev limiter cuts fuel, which is bad when spraying because it can go lean.
do i need a window switch? how do you think it will run
By burnin red in forum NitrousReplies: 2Last Post: 10-17-2007, 06:49 AM -
Camaro Window Switch/1le window/power lock delete kit
By Marc1130 in forum Parts For Sale / TradeReplies: 0Last Post: 03-12-2007, 11:05 PM -
Window Switch FS
By juiced99ws6 in forum Parts For Sale / TradeReplies: 0Last Post: 04-04-2006, 04:04 PM -
RPM window switch, and WOT switch
By corvettelover in forum Parts Wanted / TradeReplies: 1Last Post: 12-02-2005, 12:21 AM -
Window Switch Help
By Richard Nock, Jr. in forum NitrousReplies: 12Last Post: 08-25-2005, 05:25 AM
