06-02-2006, 12:26 PM #1danmanGuest
Headlight problem? driver side is very dim
I noticed the other day that my drivers side headlight is a lot dimmer than my passenger headlight. I put a new headlight in yesterday and it was the same way. Almost like it's got a loose ground somewhere. Anyone have any ideas?
06-03-2006, 07:49 PM #2
Did ya check the fluid leveL?
Try changin the "bright" bulb with the "dull" bulb and see if the problem is reversed. If the light isnt flickering chances are it isnt a ground, check around behind the headlight for a dirty or corr. ground. Could it be just not adjusted right?
06-04-2006, 03:38 PM #3danmanGuest
I did switch them out with one another and the passenger side was still dim in the drivers side light. It's not just the adjustment. I can turn the lights on in my garage and the passenger side is very bright and the driver side looks very dim.
06-05-2006, 06:26 AM #4
If you have a multimeter you can see how much voltage you are getting at the socket and if you think its the ground you can try and externaly ground it.
Take a small piece of wire and put in with bulb, between the bulb and housing and then ground somewhere on frame and see if it gets any brighter.
J
Help: pcv driver side
By Nick Schiro in forum Firebird / WS6Replies: 1Last Post: 10-04-2016, 12:10 PM -
Wanted: Driver Side Headlight Motor
By TruThug in forum Parts Wanted / TradeReplies: 0Last Post: 09-08-2013, 04:48 PM -
Wanted: Driver side T-Top
By SVG210 in forum Parts Wanted / TradeReplies: 2Last Post: 08-10-2008, 10:25 AM -
Need driver side headlight assembly
By 98grnbird in forum Parts Wanted / TradeReplies: 0Last Post: 07-22-2008, 02:33 PM -
For Sale DRIVER SIDE HEADLIGHT ASSEMBLY, Fender, and 3.73 gears
By Brad8169 in forum Parts For Sale / TradeReplies: 12Last Post: 10-19-2007, 04:17 PM
