Results 1 to 2 of 2
Thread: pcv driver side
09-30-2016, 05:47 PM #1Junior Member
- Sep 2016
- louisiana
2002 trans am pcv driver side
hello i own a 2002 trans am ws6 and i was trying to remove my rotten pcv hose and it was deteriorated in the front and in the back behind the intake manifold and now i cant get the other half of the hose off the drivers side theres too much stuff in the way to pull the hose out
10-04-2016, 12:10 PM #2Spaz is My Mentor
The rear of the drivers side valve cover you will see a port that connects to the hose and the cover. With a flat tip screw driver you can pop it off and carefully remove the hose around the back of the intake. There is on the same side your OPSU (Oil Pressure Sending Unit) that is very, very easy to crack. After you snake the pcv hose out you have a few options that are a hell of a lot cheaper to fix it then buying the replacement one and still have a badly design product.
http://www.ls1.com/forums/f6/pcv-val...ication-80151/
http://www.ls1.com/forums/f6/explain...ct-mod-156010/
http://www.ls1.com/forums/f63/ls6-va...r-pics-145557/
These all came from here:
http://www.ls1.com/forums/f6/technic...tickies-79083/
Wanted: Driver side T-Top
By SVG210 in forum Parts Wanted / TradeReplies: 2Last Post: 08-10-2008, 10:25 AM -
WTB Driver side T-Top
By One_Bad_TA in forum Parts Wanted / TradeReplies: 1Last Post: 08-02-2008, 11:11 AM -
help with driver side DRL
By BlkTA00 in forum General HelpReplies: 2Last Post: 07-16-2007, 04:23 AM -
driver side t-top
By stangkillerta99 in forum Parts For Sale / TradeReplies: 3Last Post: 10-03-2005, 08:46 PM -
Driver Side T-top!!
By BeelowSS in forum Parts Wanted / TradeReplies: 4Last Post: 10-02-2005, 07:19 PM
