Results 1 to 11 of 11
    sarasota florida
    white/blue
    99 transam
    gear change, went slower, what gives?
    I just changed up from a 323 to a 373 in my 99 convertible a4 auto ws6 car.
    Here is the strange part, I went 2-10ths slower. I had a best of 13.48 in February with 77 degree temps, dry air. Just went to the track and ran a 13.70 with a about a 85 dgeree and more humid day. My 60' times on both runs were 1.943 and 1.972. Anybody experience anything like this? I thought the gears would give me a couple tenths?
    MODS, 99/t/a, 2800 vigilante stall, hooker cat back, ported throttle body, slp lid, computer tune. Stock exhaust manifolds and y-pipe.
    One guy tells me since I don't have headers that the car is just choking out sooner with the steeper gears since it can't breath without headers. Anybody heard of this equation?
    Thanks for any help,
    [email protected]
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    might want to change your shift points, and also does you car shift into OD while in the 1/4th because that will take more time
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    some of it is in the hotter and more humid temps right now. i only saw a tenth when i went from 3.23 to 4.10. same when i went from a stock converter to the yank PY3400E. difference being winter to summer.
    Junior Member nabdrill's Avatar
    Northeast Louisiana
    Hugger Orange
    98 Camaro
    something is not right. I went from 3.23 to 3.73 w/ a 3K conv and picked up almost half a sec in the 1/8th.
    How do your 1/8 mile compare
    Member silverTA2002's Avatar
    Bradenton, FL
    2002 Pontiac Trans Am
    More importantly than your 1/4 mile time...... what is the MPH change?
    You could be spinning more than you think now.
    sarasota florida
    white/blue
    99 transam
    mph in the 1/8 and 1/4
    Allright, in the 1/8 mile with the 323's and 15 degree temp change i had a 8.697/ 82.31 mph, 1/4 was 13.48 @ 102.38 mph. the temp was cooler.
    1/8 mile with the 373's and 15 degree hotter temp, 8.799/80.28 mph, 1/4 was 13.65 @ 101.91 mph, this is what is boggling my mind, the 1/8 mph is slower with lower gears, makes no sense. the car is hooking well, i feel virtually no spin with the heated up drag radials. One guy mentioned the shift points, this could have a factor as they are set at 6000 rpm in all gears. I can't remember if the car went into 4th in the 1/4. it never did with the 323's but that is different. But even doing a burnout, the car just feels like it has lost power, i virtually did not notice one power change when I changed from 323's to 373's. only thing is it shifts sooner, nothing else. it is very dissapointing as i thought i would get something out of the swap.
    thanks for any help.
    andy
    Bradenton, FL
    Shift points SHOULDN'T be changed with a gear swap.
    Proper shift points are determined by the transmission gearing in each gear and the Torque you're making at different rpms.
    Rear end ratio and tire size, etc. do not affect shift rpm.
    2002 Trans Am 6sp, SLP lid, Holley filter, Shaner S3 TB, Jet Hot long tubes and cats, FRA, HP tuners, Hotchkis STB and LCAs. TEA stage 1.5 5.3 heads, Comp 220/224 114 +2, UMI Boxed SFCs, Edelbrock PHR. Moser 9" 4.11 gears.
    **FOR SALE**: http://www.ls1.com/forums/showthread.php?t=60478
    Member 98Z-28Camaro's Avatar
    Oklahoma City
    1998 Z-28 Camaro
    Quote Originally Posted by ss~zoso~ss
    How can you speed up the od shift speed? Any tricks to doing this?
    Member silverz28camaro's Avatar
    Washington MO
    sebring silver
    2000 z28
    on a cool night my car ran a 13.1 , a week later it was about 15 degres warmer and my worst was 13.7 (WTF) i thought , but as the night cooled i did run a 13.3, temp plays a big part go back when the temp drops
    OR, next time i go i am going to put a cool jel pack on my intake to see if that helps out with more dense air, also let the car cool don't do such a massive burnout, that will heat the engine compartment up, get a cooler thermo and programer to lower fan operations, this will help, my 13.7 was after a huge burnout, next run i didnt do the burnout and ran a 13.59
    Play around with letting the car cool down between runs, also make sure the car is maintained well, oil plugs filter you know
    St. Louis ,Mo.
    pewter
    1999 pontiac formula
    Like silver says I think the Florida heat is slowing you down.
    I envy the guys in New Jersey with that low alltitude and great DA
    they really run fast.
    Ohio
    Gold
    1998 Formula
    If you did not change your gear ratio in your computer that is the problem.
    You need to flash the new gears to have everything back to normal look at your speedo it is off also if you did not change these values in your computer.
  1. 3.73 Gear Change?
    By bhunter0830 in forum Firebird / WS6
    Last Post: 09-11-2012, 08:18 AM
  2. Change Gear Ratio
    By bberretta in forum Manual Transmission
    Last Post: 12-05-2009, 10:52 PM
  3. gear change on stock ws6.
    By barryz in forum Drivetrain
    Last Post: 02-13-2009, 04:19 AM
  4. Steps to take for a gear change?
    By Nero.Jacinth in forum Drivetrain
    Last Post: 07-18-2007, 04:21 PM
  5. gear change
    By silverz28camaro in forum GM Trucks
    Last Post: 12-25-2006, 04:16 PM
