Thread: 3.73 Gear Change?
09-04-2012, 11:01 AM #1
3.73 Gear Change?
So I have a stock 10 bold rear end with the 2.73 gear. Is it possible to make a change to a 3.73 or 3.42 gear? Everywhere I look to order states that I need to change to a "Series 3 Carrier". Can someone help explain that to me?
Thanks!
09-07-2012, 08:19 PM #2Exalted Cyclops
- Feb 2007
- San Diego, CA
While that was true at one point in time, the aftermarket currently makes a thicker gear that will work with the 2 series carrier.
09-08-2012, 04:57 AM #3Former Mopar Man
- Jun 2011
- Branchville, NJ
Yes you can. I would call Richmond gear for choices since they have a great selection of ratios for your vehicle. I would normally recommend you replace your tiny 10 bolt with an aftermarket 9", 12 bolt or S60 but it looks like you have an automatice trans and I do not see a bunch of mods listed so a set of quality Richmond gears should live fine in your rear. Good luck and let us know how you make out.
09-08-2012, 03:29 PM #4
Mod's if that makes a difference:
BBK LT's, ORY, SLP LM2, SLP Cold Air Intake, Wide Band O2, Deleted AIR & EGR & Tuned By Frost, Founders STB, LCA's & PHB.
09-10-2012, 08:32 PM #5Former Mopar Man
- Jun 2011
- Branchville, NJ
It does make a difference since the more HP you have and the harder the trans shifts will have an effect on the life of your rear. You have to remember that most of these cars with bolt on mods have 400 Net HP and they have these tiny 7.5" ring gears. It just does'nt add up.
09-11-2012, 02:59 AM #6
Upgrading the stock rear is a gamble. It just isn't beefy enough for what our cars are capable of. Do you have plans for the track or sticking to the street with it?
09-11-2012, 06:58 AM #7
09-11-2012, 08:18 AM #8Spaz is My Mentor
Here's something interesting about Richmond Gears that I did not know.
They were acquired by Motive Gears. Not sure exactly when this happen
Motive Gear Press Releases and Media
Question: Rear end gear change
By SuperSleeperBenz in forum DrivetrainReplies: 12Last Post: 11-16-2016, 03:25 PM -
Change Gear Ratio
By bberretta in forum Manual TransmissionReplies: 2Last Post: 12-05-2009, 10:52 PM -
gear change
By silverz28camaro in forum GM TrucksReplies: 3Last Post: 12-25-2006, 04:16 PM -
gear change, went slower, what gives?
By Andy Lappin in forum Drag RacingReplies: 10Last Post: 06-22-2006, 01:35 PM
