Results 1 to 2 of 2
05-26-2006, 10:38 AM #1Sonoma GT w/416 L92/T56
- Sep 2005
- Humble Tx 77396
Black- 1992 GMC Sonoma GT
Does anybody make a 13" or bigger rear disk kit for 98+ f-body?
Hello, ive been searching and searching with no luck and wanted to find out if anybody or company out there makes a bigger than stock rear disk upgrade for the 98+ f-body. Seems all the kits just have bigger/more pistons in the caliper but keep the stock 12" diameter rotor.
I have C6 ZO6 14" rotors/6 piston PBR calipers on my Project Sonoma GT, and i have installed 98+ f-body 12" stock brakes on the rear, but wanted to use the 13.4 C6 ZO6 rear rotors and 4 piston calipers, but the rear rotors have a shallower hat for the parking brake and wont work, Id love to have a 13" or 13.5 rear rotor that will work with the ZO6 caliper or even the stock f-body rear caliper.
Please tell me in not SOL on this, and point me in the right direction?
Also has anybody tried swapping C5 parking brake components to see if that would allow the C5/C6 rear rotors to work on the F-body???1992 GMC Sonoma GT #492 of 806 built.
Under Full Resto w/433 E85 L92/4L80E.
1992 GMC Typhoon #1104 of 2200 built.
Broken Crankshaft. New Engine Soon.
2000 Olds Bravada
Bagged 2wd Frame Swap
L31 swap Planned
Daily Driver
05-26-2006, 10:46 AM #2your parts guy!!!
- cleveland ohio
trans am 00 ws6- 1998 camaro ss vert
check wilwood, and baer.
i have the wilwood.
For Sale: '93-'02 F-Body "Bigger" C5 Rotor Conversion Kit
By Sommer86@6LE in forum Parts For Sale / TradeReplies: 0Last Post: 10-10-2013, 09:47 PM -
"boot failure insert system disk" Computer ???
By ssgtcarroll in forum Almost Anything GoesReplies: 10Last Post: 12-13-2009, 04:50 PM -
do they make bigger MAS for v6...?
By jd1666 in forum General HelpReplies: 16Last Post: 08-03-2008, 11:53 AM -
Ford 9" Rear, So what mods will I need to make?
By Patsy57 in forum DrivetrainReplies: 3Last Post: 07-02-2008, 02:37 PM -
For Sale: Spec 3+ Clutch Disk "NEW" For Sale
By Dillard99 in forum Parts For Sale / TradeReplies: 0Last Post: 02-15-2008, 01:14 PM
