Results 1 to 11 of 11
    Member ssgtcarroll's Avatar
    East Prospect, PA
    91RS 99Z28 11GT 86Bronco
    "boot failure insert system disk" Computer ???
    Ok guys computer question:
    Getting this error on a new hard drive.
    I put the Windows XP CD in hit enter...CD drive "runs" twice...noting comes up error pops up again.
    Any ideas guys?
    Jumper is set to master...did the same on cable select.
    Tested CD works fine.
    Colorado
    99 Z28
    go into your BIOS and set it up to boot from CD first, then Hard Drive.
    It will read the CD first and say "Press any key to boot from CD......"
    That should do it.
    East Prospect, PA
    CD is set as boot first.
    BIOS does see the new hard drive.
    Colorado
    99 Z28
    IDE or SATA?
    I had that happen to me once. Even tried to hook it up to another computer via USB and at first, the drive was recognized and then nothing. Same on all my computers. Nothing.
    It was a bad HD. It happens occasionally.
    Have you tried to see if it shows up hooked up to another computer and format it?
    Junior Member loasdrums's Avatar
    Jul 2009
    NC
    Green
    1996 Acura Integra
    Quote Originally Posted by DrMilhouse View Post
    IDE or SATA?
    Quote Originally Posted by ssgtcarroll View Post
    Any ideas guys?
    Clue...
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    Is the OS already on the new drive? You could do the f12 thing upon boot up and then arrow down to your cd drive...less time consuming than changing the bios.
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    oh and switch to sata
    East Prospect, PA
    Its IDE brand new drive no OS on it. Trying to format and install a OS but seems to not recognise my CD is a OS cd or something. I will try the drive in another CPU though.
    Colorado
    99 Z28
    try no hard drive at all, just try the CD by itself and see if it will boot from the disk. You don't need a hard drive for it to boot to the installation - there just won't be anywhere to install it. Try it out and see what happens. If that's what it is, either the jumpers are wrong or the hard drive is effed.
    East Prospect, PA
    Just ran the HD on my personal computer on cable select. Got it formated fine...and XP installed. I am going to grab another IDE cable as I did not use the same cable and try hooking it up in the original computer....
  1. Nick Burns "The Computer Guy"
    By Silverado2000LS1 in forum Almost Anything Goes
    Last Post: 07-23-2009, 05:24 PM
  2. For Sale: Spec 3+ Clutch Disk "NEW" For Sale
    By Dillard99 in forum Parts For Sale / Trade
    Last Post: 02-15-2008, 01:14 PM
  3. Computer Help. Internet just says "local only", cant get on web.
    By Mike Hawk in forum Almost Anything Goes
    Last Post: 11-24-2007, 01:05 PM
  4. "02" LS1 w/harness, computer, and auto trans ALL 4 $3000
    By BigDaddy in forum Parts For Sale / Trade
    Last Post: 01-09-2007, 02:02 PM
  5. "Disk" spacers under lower airbox
    By Maul in forum General Help
    Last Post: 10-25-2006, 03:11 AM
