Results 1 to 2 of 2
    S.C.
    1998 Pontiac TransAm
    RaceTronix wiring ?
    I bought the kit awhile back , I have the instuctions for the pump ,and did'nt get the instructions for the wire harness kit from the alt to the pump. I was wondering if anyone had them and could e -mail them to me ?
    Thanks
    [email protected]
    It's very simple. Just put the wire on the nut on the back of the alternator or use the auxillary power by the fuse box then zip tie it to the fuel line under the heat shields and what not to the back of the car. Then plug the connectors in ( they basically T between the stock connectors) and mount your ground lug and relay under the bolt that holds the brake line bracket in place above the drivers side wheel. Grind the surface a little so you're on good metal and load it up with dialectric grease before putting the lug on there. That's pretty much it.
  1. Racetronix 96 lb Injectors
    By cam02ss in forum Parts For Sale / Trade
    Last Post: 11-14-2014, 03:02 AM
  2. FYI Racetronix
    By shadowsnkx in forum General Help
    Last Post: 11-29-2008, 07:36 AM
  3. Replies: 1
    Last Post: 11-16-2007, 09:41 AM
  4. For Sale: Racetronix Plug & Play Fuel Pump with Wiring Harness
    By Ed Blown Vert in forum Western Members
    Last Post: 05-21-2007, 01:13 PM
