Thread: Rear differential ticking
05-06-2006, 08:12 PM #1
I went to go look at the trans am and there is a slight ticking on the rear of the car don't know wether it's the brakes or I heard about the rear differential? How can I tell? Is it expensive? Haven't totally bought it yet, went to see a black trans am that is automatic
but its black (my favorite color) and it seems to make the same sound? Dealer said they would take a look at it and fix it, what do you guys think?
05-06-2006, 08:20 PM #2
if it is in the brakes you can apply slight brake pedal pressure and the noise should stop, if it is in diff. could be several different things.broken ring or pinion gear.side bearings or wheel bearings
05-06-2006, 08:22 PM #3
How much does it cost? Cause I still might buy the car from him just take the difference in cost to get it repaired, my gramps isn't open on sundays hes open mon-sat and all his mechanics can't go with me till monday, would like to go pick up the car tomorrow :-/
05-16-2006, 09:52 PM #4
got the same problem in my car.. all i did was have the rear checke out and cleaned out.. put the rear oil in and it was a lot quieter. after about a week the noise was back to normal. im thinking its the rear so iv been looking for ring and pinions. just need to find the right person to do it. for now im just waiting for something else to happen with it before i do anything. a whole new rear is about 2g. and since ur gramps is a mechanic ur lucky.. u can find some1 real good to do it. putting in a whole rear isnt as hard as messing with the insides.. by the way, if you do need a new rear aor pinions, go with the best, 4 10s
05-16-2006, 09:55 PM #5
please let me know what happens cause its still up in the air for me..
Rear Differential
By VinnieV02TA in forum DrivetrainReplies: 19Last Post: 10-15-2010, 09:41 AM -
Question: Rear differential...
By 99Bandit in forum Automatic TransmissionReplies: 0Last Post: 06-15-2008, 09:08 PM -
Ticking from the rear end
By whiteLS1TA in forum DrivetrainReplies: 3Last Post: 07-11-2007, 01:26 PM -
WTB Rear Differential
By Xtap in forum Parts Wanted / TradeReplies: 3Last Post: 09-17-2006, 02:13 PM -
Rear Differential ?
By CAMZARO in forum DrivetrainReplies: 3Last Post: 01-07-2006, 02:14 PM
