Thread: Whining noise in speakers
05-05-2006, 04:35 PM #1
Hey guys, i have a 99 z28 6-speed. when I accelerate through the gears, there is a high pitched whinning noise coming from one or some of the speakers that gets louder as my rpms go up and quieter when i shift into the next gear. does anyone have any idea how to fix this problem? the only thing that is not stock is my cd changer and the guy before me had subs in the truck, but they are gone now. Thanks for any help.
05-05-2006, 04:54 PM #2Junior Member
- Apr 2006
- murillo, ontario, canada
silver- 2002 TA WS6 A4-Vert
is it your stock system? my trucks after market system was wired wrong and had that whining noise, the faster I went the louder it got.
05-14-2006, 07:06 PM #3
ground issue is what it sounds like most likely an aftermarket setup I'll assume. Try a different ground location. Search fbodyaudio.com for some tips possibly.
05-14-2006, 09:26 PM #4
aight thanks a lot
99 Black Z28 - K&N, Ceramic lt headers, 3' off-road y pipe, 3' hooker cat back, 6 speed, black halo headlights, chrome Z28/LS1 emblems, SLP shifter
05-19-2006, 04:31 PM #5Junior Member
- Feb 2006
- Marietta GA
Mystic Teal Metallic 79U- 1998 Pontiac Trans Am
Same ol thing..either ground wire or the RCA's are getting interference from the power wire (battery) being too close to them. Had this problem too. Another solution is get a deck with higher voltage RCA's 4volts or more. Average HU has 1.5-2.5volt RCA's. The higher volt the RCA...the cleaner the sound and less noise. Be wary of this because if your deck only has one pair RCA output at 1.5-2.5volt and you have a 4 channel amp your splitting the already low voltage in half which will deteriorate the signal further. Always consider this when buying a deck for an amped system. Good luck!!
whining noise??
By via sin dios in forum Firebird / WS6Replies: 17Last Post: 10-29-2015, 02:34 AM -
whining noise from my rear end?
By joedude02 in forum General HelpReplies: 23Last Post: 11-22-2014, 08:50 PM -
Question: Whining sound from speakers?
By dpeach in forum General HelpReplies: 4Last Post: 08-05-2008, 09:27 AM -
whining noise 94 z28
By t-rock in forum General HelpReplies: 1Last Post: 01-14-2008, 07:40 PM -
help with whining noise please!
By 1998zman in forum General HelpReplies: 3Last Post: 03-26-2006, 01:18 AM
