Results 1 to 20 of 24
    Member joedude02's Avatar
    Goose Creek, SC
    Victory Red
    2002 T/A WS6 A4
    whining noise from my rear end?
    i have this whining noise coming from what i think is the rear end. it only makes this noise when i take my foot off the throttle for deceleration. it is a stock 10 bolt 3.23 gear. i just recently changed the diff fluid and added the additive as well. same problem but only at speeds above 25mph for deceleration. any help on this would be great cause it is really becoming a true annoyance.
    Member side2000's Avatar
    md
    2000 camaro ss
    most likely ya got a worn bearing in there. howling and whining is almost always a bearing. does it speed up as you go faster or is it just a constant whine?
    Bragg NC
    Met. Sunset Orange
    01 SS
    Was it making the sound befor you changed the fluid?
    J
    Goose Creek, SC
    Victory Red
    2002 T/A WS6 A4
    it made the noise before changing the fluid. but if i keep a little bit of throttle it doesn't make the noise. i'm kinda thinking it may be a wheel bearing. just seems to be too loud to be that. the car has only 65,000 miles and only 4k out on it this year.
    Marylandistan
    2001 Trans Am (sold)
    A little gear whine ain't gonna hurt nothin.
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    Hey Joe, does it change pitch while driving? If so, your carrier bearings might be the culprit.
    If you need rear end work in your area, go to Bouchillon Performance Engineering in Hanahan at 937 Commerce Circle(near Remount Road and North Rhett).
    tennessee
    TA-White, Camaro-Black
    Track-TA98A4 DD-98z28M6
    if it is rear end.. dont worry until it goes..
    md
    2000 camaro ss
    well the bearings are pretty easy to replace no matter where they are. especially once ya done em before. i've gone through prob three bearing rebuilds in my car from bangin turns and rippin. you can pick up complete bearing kits for cheap might as well do em all while yer in there.
    2000 red ss: >2" drop, koni adjustables 'n 275 s-compounds all way around, giant brakes, dynatech LT's, borla catback (no plate), t56, tubular everything, HARD TOP, caged, "stock" heads 'n a mean cam. -2* front camber.
    Member slpdablueZ28's Avatar
    Sep 2008
    brooklyn
    blue
    2002 Camaro Z28
    i had that too when i first bought my car. the rear end had leaked out because apparently "the seals on 98-02 tend to leak". but if u were able to change the fluid thats not ur problem
    Goose Creek, SC
    Victory Red
    2002 T/A WS6 A4
    i really wonder if its the preload or the u-joints. i just noticed some grease on the exhaust that came from the u-joint. can't re-grease it cause it has no fitting on it. guess i'll pull the driveshaft out and press in some new brutes. i'm just not used to having a quiet car like this one.
    md
    2000 camaro ss
    is it grease or oil?
    tennessee
    ujoints will make a thumping sound... not a whining..
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    mine does it too.. howls like a bitch. 3.23s. Gear whine.. normal and common
    Member Z28_06374's Avatar
    May 2008
    CT
    Run the thicker 140W, that should quiet things down a bit.
    Indiana
    2001 Trans Am
    Same exact problem
    I had the same exact problem with my rear end. I took it apart and as i was removing the c clips all you could see was metal chunks falling out of the rear end the oil was full of metal and the magnet was covered. Come to find out I had no bearing left I had driven the car far too long unchecked. It was only on one side though. Changed out the bearings and seemed to work fine for a couple weeks now I'm starting to hear a little i dont know if Im killing another bearing or not yet as i havent taken it back apart.
    What could cause the bearing to just get eat all to hell to where there isnt anything left? And it only does it on one side.
    md
    2000 camaro ss
    coulda been a number of things really. coulda just been bad parts, could be put together wrong- but as far as bearing's wearing out it really depends on how ya drive. i got my car setup for road racin and i gotta replace my rear bearings quite frequently (more than i should have to w/ normal drivin) from bangin turns. was that chewed bearing on the drivers side? that's the one that goes bad first on mine from bangin off ramps real hard. just gotta listen to the rear-it'll tell ya when it needs new bearings.
    Goose Creek, SC
    Victory Red
    2002 T/A WS6 A4
    well to bring this to a conclusion. i have finally figured out and have made the repair of this stupid whining noise. the bolt for the pinion was coming loose and causing the preload to be off. stopped after setting the preload up again.
    THE SWAMP
    2000 Camaro SS M6
    Good job on finding & solving the problem youself. How loose was it?
    md
    2000 camaro ss
    thicker oil woulda fixed that right up!
    Goose Creek, SC
    Victory Red
    2002 T/A WS6 A4
    the nut was tight by hand, but loose as a goose with the 1/2" breaker bar. i hit it with the impact and torqued it not too tight. amazing how sound travels in these cars.
  1. whining noise??
    By via sin dios in forum Firebird / WS6
    Last Post: 10-29-2015, 02:34 AM
  2. Random whining noise from the rear
    By Archaelas in forum Drivetrain
    Last Post: 03-12-2010, 06:33 AM
  3. whining noise 94 z28
    By t-rock in forum General Help
    Last Post: 01-14-2008, 07:40 PM
  4. Whining noise in speakers
    By Black-LS1 in forum Stereo and Electronics
    Last Post: 05-19-2006, 04:31 PM
  5. help with whining noise please!
    By 1998zman in forum General Help
    Last Post: 03-26-2006, 01:18 AM
