Thread: LS Heads (806)
08-31-2020, 03:17 PM #1Junior Member
- Aug 2020
- Coatesville, IN 46121
Blue- 02 Silverado
LS Heads (806)
Hey Guys (and gals)!
New here so bear with me in the event that I make mistakes.
I read where 806 Heads were manufactured till 98.
I have an 02 Silverado. 5.3 LM7
The block that I am rebuilding is 5.3 from an 04 Silverado.
Will these 98 806 heads fit my 04 5.3 block? If so can anyone tell me which head bolts to use because i'm finding mixed info concerning the Bolt lengths
09-01-2020, 08:24 AM #2Spaz is My Mentor
Will they fit and work? Yes
Do you want to - not really.... 241 heads are better, 243/799 best when talking stock heads.
The 806 heads are literally 1st gen heads, have a perimeter bolt pattern for the valve cover. Which means you need that cover and IIRC the coil packs bolt directly on the cover vs a bracket that holds the packs together.
Flow is meh even when ported.
You should look for 317 or 243/799 heads with the emphasis on the later for NA builds, if going boost then the 853's.
You can get a pair of stock 243/799 heads for around $500.
243 and 799 heads are the same head, just some slight differences - valve stems (hallow vs solid) and where they were cast.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
6.0L Block - Forged 403ci
, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
09-01-2020, 08:27 AM #3Spaz is My Mentor
I'm also going to move this to a section that will give it better visability
09-24-2020, 02:42 AM #4Junior Member
- Sep 2020
- Stockton
Does anyone have problem with the heads fitting I got a98 fire bird with a ls1 and it’s giving me all the trouble the steering shaft is in the way
Sent from my iPhone using Tapatalk
Late-Model GTO Heads and Cam - The Voice Inside Our Heads, P
By Ed Blown Vert in forum GTOReplies: 0Last Post: 03-16-2011, 10:30 AM -
By Ed Blown Vert in forum GTOReplies: 0Last Post: 02-04-2011, 03:00 PM -
AFR heads VS. Ported and beefed up stock heads.
By hutcher04 in forum Internal EngineReplies: 10Last Post: 03-14-2010, 09:27 AM -
Affordable Cylinder Heads - E-Street Heads
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 07-14-2009, 02:20 AM
