    see you in my rear view
    Boiling Springs SC
    2001 WS.6 Trans AM
    Cam Swap Question??
    hey everyone,
    I'm about to swap my stock cam in my 2001 WS.6 to a comp .581. I bought new comp beehive valve springs but I am getting told two different things about the lifters. Some say they won't show any wear and will be fine to leave in and others say they will have worn to the stock cam settings and will need to be changed for sure. I am in the dark here and was wondering if someone could shed some light. Thanks for your help.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    in the old days of the flat tappet lifters, you have to change the lifters as they wear into the cam. with roller cams, like the one in the LS1, you do not need to swap the lifters. they can be used over and over. this is so long as there is no wear on the rollers. which there is very little chance of that happening. so, swap away.
    Junior Member 00SLPSS's Avatar
    Feb 2006
    South FL
    from most all reasearch I've done, you'll be fine with leaving the stock ones in there. That's what I've gotten out of the searches, and even on ls1howto they don't say really anything about changing lifters.
    If anyone has other reason let me know, I'll be putting my cam in next week finally.
    Boiling Springs SC
    2001 WS.6 Trans AM
    Thanx for the info guys. hopefully it will be in my car in a week.
  1. T56 swap question
    By 98TransAmWs-6 in forum Manual Transmission
    Last Post: 06-16-2012, 08:37 AM
  2. Intake Swap Question
    By splitfinger09 in forum External Engine
    Last Post: 05-08-2008, 12:19 AM
  3. To Swap, or not to swap, that is the question.
    By HasselZ28 in forum Camaro / SS
    Last Post: 08-11-2007, 07:58 AM
  4. Gear swap question? Please help
    By firemedic0135 in forum Drivetrain
    Last Post: 07-07-2007, 11:03 AM
  5. Cam swap question
    By Hot Black Trans-Am in forum Internal Engine
    Last Post: 10-24-2006, 11:33 AM
