Results 1 to 3 of 3
Thread: LS Swap No Spark VATS?
01-11-2020, 08:03 AM #1Junior Member
- Jan 2020
- USA
I just put a 2006 LQ9 (Vortec 6.0) in a 1956 Chevy and I have no spark.
No Codes. All grounds look good.
Can the VATS prevent spark?
I was under the impression I could fire the thing up and the VATS would shut the engine down after 3 seconds so I could at least make sure it runs before I program the computer. I have not got the VATS removed from the PCM yet.
Thanks for any help.
07-12-2021, 03:35 PM #2Junior Member
- Jul 2021
- Plymouth MA
Red- 1957 Chevy bel air
with VATS it should start for a second or 2 then shut down. do you have RPM showing when cranking it over ? you can check with a scan tool. bad crank sensor will prevent spark. Another common problem, is the wire people use to switch the ignition relay, has to remain hot while cranking.
07-13-2021, 04:15 AM #3Junior Member
- Jan 2020
- USA
Hey - thanks for the reply! A little late
BUT, your second comment was exactly what it was.
The old Chevy ignition switches would kill power to the ignition wire during crank. So, I made a little jumper wire, with a diode on it, that goes from the hot leg, during cranking, to the ignition wire and it works great.
Thanks again for your reply.
PS: In case someone else runs into this problem, I got the pic below and more info from the Online Hot Rod & Custom Car Magazine - MyRideisMe blog (I think).
Chevy Big Block Distributor Swap - Droppin' Spark
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 06-04-2009, 01:20 AM -
Help: tpi swap vats problem
By crashandburn_01 in forum General HelpReplies: 2Last Post: 08-22-2008, 05:41 PM -
VATS????Security problem with the VATS.
By LS1RacerMan30 in forum General HelpReplies: 14Last Post: 07-14-2007, 07:39 AM -
Spark plug swap on GTO
By Goatdriver in forum GTOReplies: 5Last Post: 09-18-2006, 03:42 PM
