Thread: Low voltage cause WOT issuers ?
10-21-2019, 09:45 AM #1Junior Member
- Sep 2017
- East Tn
Red- 2002 Camaro SS
Hey I was at the drag strip over the weekend and was entered in a race when my alternator went out, in my data log it showed the voltage was around 11.0-10.9. My car is a nitrous car. It seemed down on power that night by at least 0.2 and 3 mph in the 1/8 mile. I was wondering if that could have been the problem?
10-21-2019, 10:00 AM #2Spaz is My Mentor
Belt slippage?
10-21-2019, 04:31 PM #3Junior Member
- Sep 2017
- East Tn
Red- 2002 Camaro SS
No sir the alternator just went out.. idk if that would hurt performance at wot only having 10.9 - 11.0 volts going down the track ?..
10-22-2019, 09:02 AM #4Spaz is My Mentor
If it's not charging the system then yes. That's why between runs at the track teams will throw a charger on or swap in a fresh battery so that the voltage is at full charge when they don't run an alternator on their setups.
If the battery is weak or near dead the coils aren't getting enough to generate full spark, which will lead to miss-fires. As the engine revs up the spark fired is more frequent.
Another possibility could have been the Air Density Pressure. Hot days/nights have less dense air which means less power. Cold days/nights = more dense air = more power.
All engines have to factor this in whether they are NA, Nitrous, or boosted. It's why most boosted cars run air coolers with ice water for the track.
I'm tempted to lean towards the air density issue more so then the alternator.
TPS voltage
By 98TransAmWs-6 in forum General HelpReplies: 29Last Post: 04-26-2016, 09:51 PM -
Low Voltage, Why?
By Z28boy2000 in forum General HelpReplies: 32Last Post: 02-27-2014, 06:17 PM -
Low Voltage
By adamz02ss in forum General HelpReplies: 16Last Post: 08-08-2012, 04:22 PM -
Low voltage
By Art99SS in forum General HelpReplies: 1Last Post: 06-02-2009, 04:34 PM -
voltage
By tingo99 in forum Internal EngineReplies: 5Last Post: 08-06-2008, 06:47 AM
