Results 1 to 3 of 3
Thread: 02 tach
02-20-2018, 09:33 AM #1
- Jun 2012
- florida
02 tach
My tach turns on and off every minute or so. Whats the problem.
02-20-2018, 03:09 PM #2
That's an odd issue. Do you have a scanner that you can plug in to see if the tach reading on it also drops in and out? I presume the tach runs off the crank position sensor, but I am not 100% on this without checking a schematic.
02-20-2018, 04:51 PM #3
- Jun 2012
- florida
Well, thats interesting because I have been getting that P0343 code, crank position sensor. That could explain things. When you say scan tool do you mean the TECH II? I noticed in the manual that you need a "scan tool" to sync a new cluster, is that a TECH II also? If not, what other scan tools can do this task? p.s., the schematic shows jack.
Help: Vss & tach
By jking78 in forum LSx Retrofit and SwapReplies: 1Last Post: 08-19-2018, 10:33 AM -
no tach
By CHRISFORMULA in forum General HelpReplies: 6Last Post: 08-25-2010, 09:05 AM -
Question: tach out put wire
By butchjr15 in forum General HelpReplies: 3Last Post: 05-20-2009, 06:49 AM -
LS1 vs C3 tach
By Zmanx in forum Stereo and ElectronicsReplies: 1Last Post: 12-06-2008, 09:38 AM -
tach
By guy in forum Firebird / WS6Replies: 1Last Post: 10-28-2006, 09:41 AM
