    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    LS3 block and LS2 heads?
    Anyone ever hear of someone using a LS bare block and LS2 heads? Trying to think of a way to go to a 6.2 liter and keep the 24x reluctor and the rest of the wiring and conversion to a minimum.
    Not that I have heard on here. The LS2 heads are cathedral port, right?
    Sep 2010
    Bel Air, Maryland
    They are cathedral port but I would be using my LS6 intake, or a FAST .
    The idea is to minimize the amount of wiring change / system conversion.
    get a LQ4 or 9 from 99 to 04 yrs. They are 24x. As a 6.0 liter you have a near perfect base. It can use LS1 or LS3 style heads.
    In addition you have many configurations to get desire builds.
    If you need more info hit me up.
    Also you can't use LS1 style heads with a LS3 block. The bore size is too great and you would have gasket issues.
    Plus it would be like making an Olympic athlete breeze thru a straw while running a triathlon.
    Sep 2010
    Bel Air, Maryland
    Thanks for the info,
    If I do go 6.0 liters, I'll buy a LS2 bare block, or a decent priced used long block. I know it costs more but I still want an aluminum block for my build, so I can keep as much weight off the front as I can, and push weight distribution rearward.
  1. Question: 92k lt1 is block ok for heads and cam?
    By RollingD in forum LT1
    Last Post: 06-04-2010, 07:54 PM
  2. LS2 heads on LS1 block?
    By krazykarl454 in forum Internal Engine
    Last Post: 03-05-2009, 02:57 PM
  3. ls1 heads on lt1 block?
    By 30thANNz28 in forum LT1
    Last Post: 01-11-2008, 01:39 PM
  4. LS1 Block LS6 Heads
    By bigboykilroy in forum Internal Engine
    Last Post: 01-07-2008, 03:57 AM
  5. Where to take block/heads in IL?
    By A RAIR 99 in forum Internal Engine
    Last Post: 09-13-2007, 10:46 PM
