Thread: LS2 heads on LS1 block?
03-05-2009, 03:46 AM #1
so i came across a pretty good deal on a set of LS2 heads. now from what i've read the ls2 heads pretty much have the same specs as LS6. (i think) plus it has a higher comp. ratio then the LS6 heads when running flat tops. i think around 10.9:1 instead of 10.5:1. so my question is?.... why are people running these heads on ls1 blocks? is there sumthing im missing? a reason they WON'T work? well thank for any info u can get me.
03-05-2009, 06:51 AM #2
ls2's use 243 heads which are ls6 heads. They'll flow better than ls1 heads but I would recommend getting them ported and polished.
03-05-2009, 08:16 AM #3
ahhh.... i c
so would the higher comp. ratio be true to them on a ls1?
03-05-2009, 02:46 PM #4Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
Yes they have smaller combustion chamber therefore you will see an increase in compression ratio. LS2 243's are identical to the LS6 casting except that they do not use the light weight valves.
Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
03-05-2009, 02:57 PM #5
ls1 heads are 10.1:1 and ls6 heads are like 10.4 or 10.5:1...... I forget which.
LS3 block and LS2 heads?
By Whamhammer in forum Internal EngineReplies: 4Last Post: 12-26-2016, 12:29 PM -
Question: 92k lt1 is block ok for heads and cam?
By RollingD in forum LT1Replies: 39Last Post: 06-04-2010, 07:54 PM -
ls1 heads on lt1 block?
By 30thANNz28 in forum LT1Replies: 31Last Post: 01-11-2008, 01:39 PM -
LS1 Block LS6 Heads
By bigboykilroy in forum Internal EngineReplies: 4Last Post: 01-07-2008, 03:57 AM -
Where to take block/heads in IL?
By A RAIR 99 in forum Internal EngineReplies: 4Last Post: 09-13-2007, 10:46 PM
